new engine starter wont work
Old 10-03-2012, 11:22 PM
greasemykey's Avatar
crank fuse is still good. pulled it and replaced it anyway and still nothing
Old 10-03-2012, 11:23 PM
where does that wire come from?
Old 10-03-2012, 11:25 PM
Custm2500's Rude Friend
1FastBrick's Avatar
The IGN 1 is the 10 amp he is referring to under hood I believe.
Old 10-03-2012, 11:30 PM
TXSZ66AVLANCHE's Avatar
Wire comes from starter relay in fuse box under the hood. Ignition triggers starter relay which sends power to starter solenoid. Try jumping relay manually.
Old 10-03-2012, 11:32 PM
what two pins do i jump?
Old 10-03-2012, 11:34 PM
With key on see which pins have power first
Old 10-03-2012, 11:40 PM
3 pins have power. 85 86 87 but two of them only have about 2 volts or so.
Old 10-03-2012, 11:42 PM
1FastBrick's Avatar
I found a diagram online for you.
Did you say in your other thread that you tested the relay as well or swapped it with one similar???
Old 10-03-2012, 11:44 PM
i think that diagram gave me a headache. lol ok ill try and figure it out
Old 10-03-2012, 11:47 PM
yes i swapped with the ignition relay thats next to it. its the exact same one.
Quick Reply: new engine starter wont work
