New Converter, what to change in tune????
Old Oct 9, 2008 | 12:12 AM
nonnieselman's Avatar
Originally Posted by SRT10KLLR
Mine does that too ever since the install of the higher stall converter. I also seem to get a shutter when it happens but if I give it more gas then it scoots pretty good. How do I fix it?
Also, after the tc it does not shift as hard as it used to with the stock unit. It used to light up second pretty good but now I have to give it more gas to chirp from 1-2. I have the tow/haul set with more trans press to get firmer shifts for when I am feeling spirited or for a day at the track.
You increase your TCC apply speeds. (D1003)
but make sure you adjust your Release speeds also ( D1006)..
the higher stall takes some of the "Hit" when it shifts..
btw srt10kllr, justin got me all straightened out with my tune.. well kinda. haha
Old Oct 9, 2008 | 12:22 AM
SRT10KLLR's Avatar
Former Vendor
Do I increase both D1003 & D1006 or increase one and decrease the other? Also, how much should I increase it by? Is it just a trial and error?
BTW, I have a 2600 stall.
Glad to hear Justin fixed you up.
Old Oct 9, 2008 | 12:44 AM
well if you want it to lock up a lil later you can increase your D1003 "Normal Column".. try adding 5mph and see what you think about it..
You can also add 5mph to D1006 "Normal Column"
Say it is locking up at 50mph right now... add 5mph. and your goin to be locking it up at 55mph..
Then on your release table you add 5mph to it and your goin to release the converter clutch 5mph earlier so it doesnt bog.. instead of unlocking at 45mph, your goin to release at 50mph
You can shoot me a email if you want to.. i get my emails on my phone and its easier to use than gettin on here with it...
Old Oct 9, 2008 | 08:44 AM
BlackGMC's Avatar
Resident Retard
Originally Posted by 95 bright teal
So are you keeping the 220/220? I am awaiting track times!!!
not sure what to tell you about tuning im a newb
Yep I am keeping the 220 cam, I might bump the compression up a little bit... I need to do something with my exhaust cause the higher stall keeps the truck at alot higher RPM, and my exhaust is gettting on my nerves.....
Originally Posted by 00ChevyScott
I have a feeling I'm still going to be faster... because you're not gonna get any traction now.
unless you go buy slicks and make traction bars before wednesday
Maybe, I dunno... Hopefully I can finish my freakin tune....
It was pretty funny yesterday, my brother was following me home in my beater and I stopped at a stop sign, stalled up the struck to 1000rpm and then just hammered it, smoked the tires threw the intersection getting a little sideways... My brother said there was an old lady at the stop sign too that was just shaking her head.... Well I finally have proof my Trutrac works...
Old Oct 9, 2008 | 05:08 PM
07 z71 silverado's Avatar
11 Second Club
mine locks up in 4th at 55. the shift will be softer but instead of spinning it will just push the truck alot more even though mine still spins the shift sometimes.
Old Oct 9, 2008 | 05:45 PM
BlackGMC's Avatar
Resident Retard
Update: I fixed the idling problem... All I did was adjusted the Desired Airflow table down some in gear and just a little bit in P/N.... Logged my LTFT at idle and applied the correction to the MAF table and now it idles like a champ, no stalling at all.... From the log it flashes to about 3100... So I am exremely happy!!!!
Choda
Jan 22, 2026 02:03 PM
LCHEE
Oct 24, 2020 04:10 PM
1979rs/z28
Sep 23, 2015 08:39 AM
KyleW707
Jul 29, 2015 08:17 AM
GMCtrk
Jul 17, 2015 06:39 PM
