New cam tune
Old Oct 9, 2011 | 07:53 PM
08k1500_3's Avatar
Default New cam tune
08 Sierra 5.3.
I am swapping out my cam hopefully this week or next weekend.
I have done some basic engine tuning and have done alot of trans stuff for my truck.
I dont have the slightest idea where to start after I swap out this cam for my new one. (TSP 224r. 224/224 .581/.581 112lsa)
I am using HP tuners.
Really hopeing for a base tune to start with or a general idea where to go with from my current tune.
Thanks
Old Oct 12, 2011 | 05:06 PM
08k1500_3's Avatar
Got the cam in and truck is running decent. It wont start on its own though. I have to give it alittle bit of throttle for it to start. Any ideas of which parameter in HPtuners I need to focus in on to make it start on its own??
Thanks
Old Oct 12, 2011 | 06:38 PM
04SilveradoMykk's Avatar
I would start with moving Idle RPM to around 800, set the Min Idle to 100rpm less and increase idle ignition timing to like 20-22 instead of 18. Than report back with what it is, or isn't, doing and we can play with idle airflow's
Edit: I just read your response and yours trucks behavior in the HPT forum. You need to add a little in the Engine>Idle>Airflow>Startup>Startup Airflow. Add 15% for the intial, if more is needed increase in 5% increments
Old Oct 13, 2011 | 08:50 AM
08k1500_3's Avatar
Ok. that worked for the idle start up issue.
I also have a random misfire on all cylinders showing on my tech 2 when the truck sits and idles. It does misfire everyonce in a great while but is running fine when the counters are going up. I have tried a crank relearn and that didnt help at all. could this be caused by the cam??
thanks for the help
Old Oct 13, 2011 | 09:50 AM
Yes, cam lump at idle will make the PCM think it's misfiring.
Depending on how lumpy the cam idles and if you ever intend to install a performance stall torque converter you may just want to turn off/desensitize misfire tables all together
ARC
57
Feb 21, 2022 10:54 AM
Matt331
Jul 26, 2015 09:40 PM
ssierra08
Jul 15, 2015 06:40 AM
4B11T
Jul 13, 2015 03:48 PM
all_individual
Jul 13, 2015 11:01 AM
