Need MAP Sensor plug pin outs please
Old Aug 31, 2006 | 03:03 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
What issues did you have Marc? Is there a thread out there I'm missing?
Old Aug 31, 2006 | 04:47 PM
TurboGibbs's Avatar
Oh, HPT software was fubared and they had to fix it and email me the updated version. I was either the first to use a 3 bar on a truck or just the 05 trucks I suppose.
Old Aug 31, 2006 | 11:11 PM
vanillagorilla's Avatar
Not to hijack, but since were on the subject of 3 bars and vacuum sources, I'm a little concerned. I'm going to be putting my 3 bar in within the week, and the 1 vacuum source for the factory manifold has my WG, BOV, and boost gauge referenced off of it. I was thinking about putting the MAP in the port behind the throttle body, but I'm not sure if there will be too much of a pressure drop there. My other option was to use the port by the fuel pressure regulator. What do you guys think?
Old Sep 1, 2006 | 01:20 AM
I AM A MOTHERF*CKER
I'm not 100% sure about this, which is why I didn't post it earlier. My physics guru is out of town...
I believe vacuum changes occur on the pico-femtosecond scale. The PCM is on the nanoscale.
Translation: the vacuum change propigates several orders of magnitude faster than the PCM can recognize anyway. As long as you use vacuum lines and not pvc pipe () I believe you'll be fine.
I ran my megasquirt, boost gage, hobbs switch for the fuel pump, meth kit and fpr off the same port with no appreciable loss of performance. I also run a long line from my manifold to my wastegate under the bed. I did this after talking to my physicist friend before the install (His exact words were: "Vacuum is vacuum. Hook them all together").
Marc's post above makes logical cents (pun intended) however, and I'd like to hear my friend explain it away.
Old Sep 1, 2006 | 09:41 AM
TurboGibbs's Avatar
I have nothing to prove with any experience that you would have problems with extremely large or small volume of lines. Just offering my .02
And my name is spelled m-a-r-K
Just don't tell "the man"
Old Sep 1, 2006 | 10:45 AM
I AM A MOTHERF*CKER
hehe I hate it when people replace the 'k' in my name with a 'c' so I always try to get the spelling right -- sorry about that
Old Sep 2, 2006 | 03:41 PM
Well it looks like you're not the only one MarC
I just went to do a 3bar OS on my truck and nothing happened. I have 3 bar enhanced applied and my VE table goes up to a whopping 105kPa. This sucks! I just used 2 credits for nothing. I guess I'll email them my tune.
Old Sep 3, 2006 | 04:35 PM
TurboGibbs's Avatar
Yep, same deal with mine. I had to uninstall HPT and reinstall the update they sent me. They were right on top of it. Took a day or two though.
ullose272
Aug 5, 2016 02:05 PM
Slammed96
Jul 27, 2015 07:22 AM
Ketis
Jul 23, 2015 12:37 PM
jrplz
Jul 9, 2015 12:07 AM
