Need MAP Sensor plug pin outs please
Old Aug 31, 2006 | 09:30 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Default Need MAP Sensor plug pin outs please
Going to put in my 3 bar map finally. I need to know the pinouts for the MAP plug please.
Old Aug 31, 2006 | 10:51 AM
Yelo's Avatar
A. 5-volt supply
B. Signal
C. Ground
Just because I drive a Mustang now doesn't mean I've forgotten my roots
Old Aug 31, 2006 | 11:07 AM
TurboGibbs's Avatar
well, I was going to say that you beat me to it but the info I found is different. I'm pretty sure this is the thread I used before. I can varify when I get home and look at the truck.
https://ls1tech.com/forums/showthrea...ght=map+wiring
Old Aug 31, 2006 | 11:27 AM
Yelo's Avatar
The info I gave is the pinout data from both Megasquirt and FAST....both use regular GM MAP's (0-3bar) so the info "should" be right, if I'm wrong please let me know !!!
EDIT: it looks like the info given in mj's reference thread is the exact opposite of the info I gave.....I wonder if this is a "semantics" issue or if FAST and Megasquirt have thier info bass-ackwards
EDIT 2: it looks like mj is right.....I was looking at the info for the standard MAP's, the 1-3bar MAP's use:
A: Ground
B: Signal
C: 5-volt supply
Old Aug 31, 2006 | 12:55 PM
I AM A MOTHERF*CKER
I read TG's thread. I don't get the whole thing about "vacuum signals" and not teeing off lines, etc. Vac is vac. It doesn't get stronger or weaker, dirty or clean.
So it looks like I need a plug for my 3bar map and then more factory-harness-hacking-fu. Maybe I'll get fancy and make a conversion plug.
Old Aug 31, 2006 | 01:22 PM
TurboGibbs's Avatar
I think common sense needs to be used on the T issue. If you have a small vacume line that is going to 4 other accessories you could have some delay issues due to the added volume of the line. Air is a compressable/expandable gas so volume & diameter of the line(s) off of the T should be considered.
I spliced, soldered and shrink wrapped my 3 bar plug with the 1 bar. I left the 1 bar plug on there so I could swap back in forth easily if I had any issues, which I did so it came in handy.
Old Aug 31, 2006 | 01:24 PM
Yelo's Avatar
Vacuum IS vacuum....but any T's or splices in the line add to the chance that you will have a vacuum leak. a MAP sensor really should have a dedicated line to it, expecially if you're relying on it for an SD tune.....
Old Aug 31, 2006 | 01:48 PM
TurboGibbs's Avatar
I understand vacuum is vacuum but you have to add or remove molecules to change vacuum and if the Map is at the end of a long line and especially a small line it won't see the change in pressure as fast as it is actually occuring in the intake manifold.
You have a qt jar full of pennies(air molecules) and gallon jar full and they have the same size opening, in the end you will end up with 0 pennies, which one will empty all it's pennies faster?
Old Aug 31, 2006 | 02:27 PM
Yelo's Avatar
I was agreeing with ya mj.....
Old Aug 31, 2006 | 02:58 PM
TurboGibbs's Avatar
I don't think that's the first time that has happened
