need help on pcm
im swaping out my 00 4.8 to a 01 5.3 my problem is my buddy has hp tuners and i was wondering if i take a drive by wire pcm can i retune it with hpt to run a drive by cable i was researching on here and someone said a 03 can go either way im not sure if someone can help help me on this
How do I change this text
Well IF you make sure all other parts of the harness are the same then maybe.. But why not just buy an 01-02? By the time you buy the new plugs, trace the wires, you could have bought a 01-02 pcm off e-bay or here for less money....
Why not? Don't say its because the IAC drivers aren't in the newer PCM, because that isn't true since the used the PCM's in the vehicles that had 4.3's in them, that were not drive by wire. Some 2004 LS1's were drive by cable, as long long as he corrected the plugs and wiring to accommodate the newer PCM, why couldn't he use it? Since there is an OS for 2004 drive by cable?
. For his application, it would just be easier for his friend to get the credits to be able to tune the PCM he has since that would be easier then trying to repin and reprogram a different PCM, just because you can tune that PCM.
There is only 1 PCM (can't remember the service number off hand) That is 03+ that is used in all the drive by cable applications. The rest of the 03+ pcm's do not have the IAC drivers
