Need help with OEM Fan wiring harness
Old Apr 28, 2016 | 03:13 PM
Jojoman01's Avatar
Registered User
Default Need help with OEM Fan wiring harness
I have a complete oem set up the fans,rad,and wiring harness from a 06 silverado I really need help on how to wire everything. There a black wire that looks cut but don't know if it got cut accidentally or ground clamps got cut off.
There is a small plug idk if that is were u get the trigger wires from or the ones that go to the pcm. And if not how could i wire it so i can control it of wen to come on and off. Any help. Preciated
Old Apr 30, 2016 | 12:06 AM
1FastBrick's Avatar
Custm2500's Rude Friend
I moved your post to a more appropriate section. See diaghram below.
Old Apr 30, 2016 | 01:00 PM
Wolftrk99's Avatar
That small plug should be the one the wires from the pcm tie into, that black wire looks like the ground!!!
Old Apr 30, 2016 | 08:12 PM
Old Apr 30, 2016 | 08:36 PM
Wolftrk99's Avatar
Originally Posted by 2xLS1
The green and blue wire coming off the relay box are supposed to go to a 2wire connectorbthe other side of which goes to the pcm....c100 in the diagram brick posted
Old May 2, 2016 | 11:03 AM
Jojoman01's Avatar
Registered User
So 2xLS1 it looks like my black wire needs to be tied off together and be joined by a separate ground wire. Because mine onay has one black wire coming from the relays towards the plug. Yours has the same one then one with a ground clamp. I'm installing all this on a 99-00 silverado.
As u can see my black wire is cut. And does anyone know which pins do the the green and blue wire go to. If im installing on a 99. Cuz i know one is used pins 42,33.thanks alot guys
Old May 2, 2016 | 12:53 PM
Wolftrk99's Avatar
Both to the same pins they came out of you lose the auto recirc feature for the ac, i havent noticed any difference other than when i turn the a/c off i dont have air coming in anymore... Always irritated me....
Old May 2, 2016 | 02:47 PM
fullboardmax's Avatar
I'm swapping an 06 harness into my 03. I already have electric fans in the truck. I assume these are the two plugs down by the pcm connectors that my stock harness didn't have? If so I will just get a factory fan harness and be done.
Old May 2, 2016 | 03:11 PM
Wolftrk99's Avatar
03up are literally plug tune and play...after you run the harness and connect everything of course....
Old May 2, 2016 | 04:26 PM
Jojoman01's Avatar
Registered User
So both the green and blue wire go into the same pin? And which pin#?
