Need help with o2 sensor codes being throw?
Old Apr 19, 2009 | 05:00 PM
TouchOfEvil04's Avatar
Default Need help with o2 sensor codes being throw?
Well i got the trans problem fiured out but now i keep throwin o2 codes. Codes that wold throw very rarely before are now poppin up about every 5 miles. Nothin in my tune has chnged other than a few things transmission related so i don't know wtf?
It keeps giving me these two codes.
PO153-HO2S Slow Response Bank 2 Sensor 1 [old/immature]
P1133-HO2S Insufficent Switching Bank 1 Sensor 1 [SES][OLD][HISTORY][CURRENT][IMMATURE]
Ichecked the tune and like i said the only changes were trans related but now these two codes keep poppin up?
Here's the kicker too i replaced the o2's with front vette o2's from the same year model 2000 silvy 2000 vette.
Oh and this started happening right after i had the tranny replaced. Any chance something got messed up during the removal/instal?
But no luck i keep getting the same crap.
Ideas?
First tune is the new one 2nd is the old one if you wanna take a look at em.
Old Apr 19, 2009 | 10:38 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Probable cause is exhaust leak. Since we had to remove the y-pipe to get the trans cleaned & in working condition (no thanks to the jokers that previously "fixed" it), you should get that sealed. Delete the codes after that, and see if the codes come back.
Old Apr 19, 2009 | 11:57 PM
I can pull it off and reapply sealent but honestly it had a nice size leak beforehand and now if it's leaking at all it's not noticable.
Old Apr 20, 2009 | 11:50 AM
budhayes3's Avatar
PT's Slowest Truck
I'm betting that a ground didn't get re-installed after the trans swap, I'd look around the back of the block and the top of the bellhousing for a dis-connected ground.
Old Apr 20, 2009 | 10:37 PM
Def. goin to do this just won't be able to do so til later this week. Gotta be up and at work before 7 and will be there til dark tomorrow.
Old Apr 22, 2009 | 06:15 AM
95ImpSS's Avatar
mentioned that to him over the phone. wasn't sure if that was the culprit, but certainly a possibility.
Old Apr 22, 2009 | 08:29 AM
white lightning SS's Avatar
Check the o2 connectors water and a small amout of corrosion will have a huge effect on the readings.
Old May 3, 2009 | 07:56 PM
95ImpSS's Avatar
Joe... any update?
Old May 3, 2009 | 09:43 PM
v8
17,16,15,14,13,12,11 Drvr
check out his post about SD tuning
murderedSS
27
Oct 12, 2015 11:13 AM
creekrat
Sep 10, 2015 12:59 AM
CammedZ71
11
Sep 9, 2015 02:05 PM
Pimpinpete
Sep 8, 2015 07:39 PM
muncie21
Sep 7, 2015 09:55 PM
