need help with efilive tune
Old Apr 30, 2008 | 08:50 PM
knuckles's Avatar
Default need help with efilive tune
all my mods are in my sig.
i cant get my truck to run. i was wondering if some one has a tune that will help get me started or can show me where to get one.
thank you neal.
Originally Posted by mods in sig
2000 ecsb, 5.3l, arp rod bolts, 9.6:1 comp with 243 heads, 211/218 114 lob sep on a 114 cl cam, obx long tubes, k&n cai with custum box, p&p tb, p&p maf, gibson single in duel exit, and efi live on the way. 6.5" lift, 35" tires, 3.73 with g80
Last edited by trever1t; Apr 30, 2008 at 10:00 PM. Reason: added mods in sig to body
Old Apr 30, 2008 | 08:57 PM
charcold-bowtie's Avatar
Uhh, i could shoot u a tune, but ur gonna have work changing it. Will it not start or just not run good. I have 44lb injectors, diff tires and rear end. And all my tunes are SD.
Old Apr 30, 2008 | 09:00 PM
knuckles's Avatar
i cant get it to start or run at this point.
Old Apr 30, 2008 | 09:50 PM
type up a litlle background. new motor or what. Wont even start, your mods dont seem to be that extreme. U sure its in the tuning at this pioint.
Old Apr 30, 2008 | 09:53 PM
gao8302's Avatar
Have you done a crank relearn or Vats yet?
Old Apr 30, 2008 | 09:59 PM
knuckles's Avatar
the truck sat for like 6 months with no motor in it wile i rebuilt the engine. does it need to relearn the crank? the truck ran fine befor the motor came out but all the mods happend at once. has good fuel and oil psi and good comp.
Old Apr 30, 2008 | 10:00 PM
nonnieselman's Avatar
So the fuel pump is working...
WIll it fire up for a second then die?
Wont start at all?
Does it turn over?
Old Apr 30, 2008 | 10:07 PM
knuckles's Avatar
right now turns over sputers like it wants to go but wont. and yes the fuel pump works and has like 50 psi.
Old Apr 30, 2008 | 10:09 PM
hum..... when you crank it up will it run for more than 10 seconds? just sputters?
Old Apr 30, 2008 | 10:10 PM
did u check all of the grounds, twice and thrice.
