Need help on a 6.2 swap
Old May 27, 2013 | 03:04 PM
6.0 single cab's Avatar
Default Need help on a 6.2 swap
Am putting a 6.2 into a 2007 gmc sierra now this truck original came with a 4,8 and this 6.2 am putting in has that vvt on it so do they sale some pig tale for it or what do i do here am stuck..???
Old Jun 8, 2013 | 03:03 PM
hog's Avatar
hog
Before you get into any of the below stuff. Is your 6.2 from a GMT800 or a GMT 900 truck, and what truck is the 2007 truck, a GMT 800 or GMT 900 truck.
GMT 800=1999-2007
GMT 900=2007.5-2013
58x to 24x reluctor conversion box
Lingenfelter TRG-002 58x-24x Crank Sensor Trigger Conversion Module - Lingenfelter Performance
Knock Sensor relocation harness
Racetronix LS1- LS2 Knock Sensor Relocation Harness - Lingenfelter Performance
peace
Hog
Old Jun 10, 2013 | 08:09 PM
MDBT's Avatar
Registered User
I thought the only 6.2 with VVT was the L92? If that's the case I think all of them are 58x Gen IV engines.
Old Jun 10, 2013 | 08:52 PM
All 6.2's have VVT just not DOD
L92 vvt/dod
L9H VVT non DOD
Old Jun 10, 2013 | 08:57 PM
TIM Z's Avatar
11 sec. Truck Mod
Yeah The NNBS was the first model to have the 6.2 , specifically the sierra and Yukon Denali .
Does your current 4.8 have VVT ? Not sure who makes an adaptor or if one is available , can you possibly install a non VVT cam and standard timing set ? I think you may be able to , Internet is your friend for this issue
Old Jun 11, 2013 | 12:25 PM
MDBT's Avatar
Registered User
L92 vvt/dod
L9H VVT non DOD
Sorry, forgot about that one.
I guess what I was trying to say is that the only 6.2L engines available with VVT are Gen IV engines and therefore are all 58x. This means the OP has a 58x engine he is trying to install. OP stated he had an 07 truck and so the 4.8L motor should have been an LY2 which is also Gen IV meaning the 24x-58x conversion specified in an earlier post isn't necessary as OP has the correct type of computer.
Back to the OP's question. From what I can tell there are 3 options with the VVT. These were all specified by members here so I am just re-cycling their information and don't know much beyond these statements. The first is to simply leave the VVT actuator unplugged, the second is to program the PCM for VVT and modify the harness (not sure how exactly this is done) and the third is to do the VVT delete.
Old Apr 17, 2017 | 12:04 AM
Holloway89's Avatar
GMT 800=1999-2007
GMT 900=2007.5-2013
peace
Hog
do you still need these parts if you have a 09 silverado with a 5.3 and the 6 speed 4l80 I believe...
Old Feb 17, 2019 | 02:55 PM
All Out LS's Avatar
I am very new to the LS world. I understand what the VVT and DOD does. What I don't understand is why we would want to delete them. My guess would be for cam upgrades and/or it effects the overall hp. I am questioning this because I am looking into dropping a 2007 L92 complete pull into a 86 Chevy C10. I am also trying to find out if this is an absolute "No, No" The L92 pull will consist of engine, harness, ecm, all accessories, fuse block, Accelerator pedal, exhaust manifolds. Possible TCM, fuel pump assembly if needed and possibly the tach if needed. I am expecting to use the 6L80e tranny behind it if possible. Will I need the body computer and fuse panel as well? Any help would be much appreciated. If someone is experienced in this please hit me up.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
zo6freak
14
Oct 18, 2015 06:43 PM
Three6GMC
Aug 28, 2015 07:56 AM
05GMC4.8
Aug 7, 2015 09:55 PM
rudvirus
Aug 5, 2015 08:05 PM
