Need help! 5.3 running like crap after cam swap
Ok i pulled diagram for 05, so pink wires are power black is ground.. Both banks ground to left side of engine... See if you have power on the pink wire while the key is on... The bank 2 injectors and coils pull power from inj1 fuse, bank 1 pulls from inj 2.... This assuming the pcm is doing what it should because you obviously have injector pulse on bank 1 anyway...
Not to steal guys thread but this was me last night.
So a little on the build. I got here running last night.
TSP 220 581 cam. PRC 2.5's long tubes. Performabuilt trans Circle D 2800.
So I started her up. Shes on Jacks. Started just fine I noticed she was running rich filled my shop up with fumes. Started to top off fluids and the get tranny set. Once I put it in gear she would not idle. Had to keep burping the gas. It has a TSP mail tune. Im thinking its to rich at Idle. It threw a code and will know more tonight due to me not having my reader at the house. Any thoughts. I see this is pretty common but dont see where any one wrote a fix. Just needing a re-tune.
if you're getting air/fuel/spark to all cylinders, the fix is a better tune.
yeah just ran obd2 codes were for heater circut board P0030 0050. I had TSP remove them with tune? All tubes are hot starts good but then acts like a vacuum leak low idle speed and smells of crap gas through out garage. verified all connections
