need to find a key on wire in the engine bay
Old Aug 4, 2012 | 10:37 PM
AndysC3's Avatar
Default need to find a key on wire in the engine bay
Im trying to wire my efan with a relay. I need a trigger wire that will turn the fan on when I turn the key on. The second fan is on a switch inside the cab. Thinking about something in the fuse box but not sure which one would work.
Old Aug 4, 2012 | 11:57 PM
oakley6575's Avatar
You need a wiring diagram for your truck. But it is very easy just to check for key hot sources.
Old Aug 8, 2012 | 08:39 AM
Suburbazine's Avatar
I tapped a 10A ECM fuse in the fusebox.
Old Aug 8, 2012 | 08:54 AM
TXSZ66AVLANCHE's Avatar
Under the fuse box, pick any pink wire.
Old Aug 8, 2012 | 09:51 AM
nonnieselman's Avatar
Why do you wanna do that?
Just probe the empty fuse slots in your fuse box under the hood, there should be atleast 2 that are hot with the key.
Old Aug 8, 2012 | 11:25 AM
Because its easy, and looks cleaner.
Old Aug 8, 2012 | 11:30 AM
woops.. meant why is he triggering it when the key is on vs with the PCM.
Old Aug 8, 2012 | 11:34 AM
Chevy_King1500's Avatar
this^ there is a set of four empty slots, IIRC, two are always hot and two are keyed use a test light fast and easy
Old Aug 10, 2012 | 10:33 PM
AndysC3's Avatar
I got to thinking, I know its never good lol
If I take the trigger wire on the relay to the battery and the ground to the pcm pin 42 on the blue connector, like it is on the org. nelson harness, and set it to come on at the desired temp, would that work? The pcm is already pinned, just have to connect the ground wire.
Old Aug 11, 2012 | 12:25 AM
AndysC3's Avatar
nevermind. I got it working
iregret
Sep 10, 2015 09:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
lxcoupe
Jul 21, 2015 02:12 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
Suburban2500
Jul 14, 2015 02:10 AM
