Need a 5speed DBC tune
Old Dec 15, 2014 | 06:19 PM
walhan_qtr's Avatar
10 Second Club
Default Need a 5speed DBC tune
I had a V6 5-speed 2001 sierra that I put a 6.0 in it. I bought a V8 ecu off a 2002 tahoe that was a auto. so now it wont start (I am guessing clutch paddle position??)
If I just jump the starter relay, the truck will run no problems. but it wont do it through the key switch.
I was told I need a file from a 2000-2001 5speed truck with Drive-by-cable.
anyone can get me a file? stock or even if it was modified I don't care as long as its from a truck that started as a 5speed truck and DBC.
it has to be a HP tuner file.
my email is walhan_qtr@msn.com
I would really appreciate it.
Old Dec 15, 2014 | 06:28 PM
robm-951's Avatar
What are you using for a harness? If using a automatic harness, you don't need a 5 speed tune, you just need to wire in the neutral safety wires into the proper range sensor wires.
Old Dec 15, 2014 | 07:03 PM
walhan_qtr's Avatar
10 Second Club
Hmmm I didnt even think about that. Is there a diagram or a thread I can look at to see what needs to be done? Thanks
Old Dec 15, 2014 | 08:57 PM
robm-951's Avatar
4l60e range selector wiring - LS1TECH
If I remember correctly, you have to jump the Pin A to Pin G ( or pin B) to tell the ECM the tranny is in neutral (or Park) since the NV3500 doesn't have a neutral safety switch on it. After this, you truck will work the same way as previous and will require the clutch pedal pushed in to start. I think the clutch switch is in series with the park neutral safety switch
Aug 21, 2015 11:33 PM
JFortner5
Aug 20, 2015 06:13 PM
Ls3silverado
Jul 31, 2015 04:22 PM
Slammed96
Jul 27, 2015 07:22 AM
oharajo
Jul 18, 2015 09:24 PM
