Nbs Sierra DIRECT Efan Install?
Old Mar 20, 2012 | 10:42 AM
dmelvin's Avatar
Originally Posted by Atomic
I think I spent about $50 making mine, but it does look nice with 10ga wire and crimped/soldered connectors.
That's roughly what it cost me to do my 3 relay setup. I learned that Justin@Blackbear turns efans on for every tune he does, so I didn't even have to get it sent back in for a retune.
Old Mar 20, 2012 | 11:23 AM
Ferocity02's Avatar
It shouldn't affect how long it takes to warm up. Since the t-stat is closed during warm up, not much coolant is running through the radiator.
Old Mar 24, 2012 | 01:25 PM
TrickyTransAm's Avatar
Originally Posted by miamisierra
lets see..Im in the process of putting the front end back on as i purchased the truck with a minor fender bender!!! Im gonna try my luck with the direct set up... Just gotta figure out wich wire (green i think) is the one for the Ac
I don't think you'll like hooking the fan relay to the A/C clutch output.
The thing will constantly kick on and off, and cause voltage spikes and screw up your idle. At least that was my experience with the standard 105 amp alternator.
Your better off hunting down the AC recirc door at the PCM for the A/C high speed option. That way it won't cycle so much.
Old Mar 24, 2012 | 01:26 PM
It does. I've already tried that option with the early 99 PCM with the constant ON fan setting, no matter what you set it to.
These fans flow a LOT of air, and cool off the entire engine while doing it.
The truck will take longer to heat up and consume a lot of fuel while doing it.
mhorn0817
Jul 8, 2017 01:54 AM
Ammadien
Jul 22, 2015 08:50 PM
ullose272
Jul 19, 2015 04:14 PM
01sierraon22s
Jul 8, 2015 11:26 AM
coryhussey
Jul 6, 2015 10:23 PM
