The mystery of the check engine!!
Old Dec 19, 2009 | 03:41 AM
Denali Dude's Avatar
Default The mystery of the check engine!!
Check engine is being a pain in the A$$ for me lately, it keeps blinking and the hp tuners cant read a code and there is a cut in it and something is holding the car i cant get all the power out i lost maybe 40% of the power and no one knows the problem.
Old Dec 19, 2009 | 06:40 AM
Grumpy5.3's Avatar
If your light is blinking, the car is seeing a misfire. now as to why you cant see it, I have no clue.
Old Dec 19, 2009 | 08:32 AM
budhayes3's Avatar
PT's Slowest Truck
There's a cut in what, the cable for the HPTuners? As mentioned, you have a misfire somewhere...get your HPTuners working and check the misfire % of each cylinder if you're just seeing a random misfire, unless of course you have a code for a specific cylinderr misfire.
Old Dec 19, 2009 | 10:23 AM
osin68's Avatar
With your HP Tuner can you retrieve Freeze frame data (History)? If you can look at the data and you should be able too determine what is causing your Check Engine Light to flicker.
Old Dec 19, 2009 | 02:23 PM
454SuperSport's Avatar
blinking light is a misfire. the tuner probably disabled the p0300 code since you have a cam, thats why it won't store it. did it start out of the blue or after doing some work on it?
Old Dec 20, 2009 | 04:45 AM
it started like that and what i meant with cut is that i go wot and the car freezes and unfreez back and keep going like that.
Old Dec 20, 2009 | 09:16 AM
05_GMC's Avatar
I have this same problem, only the light quits flashing when i start driving it
Old Dec 21, 2009 | 05:27 AM
here its the opposite it starts flashing while driving
Old Dec 21, 2009 | 08:05 AM
dewmanshu's Avatar
Moderately Differentiated
If the light flashes then you are outside the misfire parameters and you should get a stored code. I have tuned my misfire calcs pretty wide but I have got the flashing SES light and it still set a P0300.
Then your tune isn't fully tuned for your cam. Cam's (larger ones) will cause misfires at idle especially.
Once it stops flashing does the SES stay lit? I agree with every one that a flashing SES means misfire, but if it doesn't set the light once it is done misfiring...then that's a new one on me. Maybe that's what 454supersport is getting at. The misfire parameters are so far out that it won't set the code. But that doesn't make sense to me in the long run. If the pcm sees a situation it usually stores it, all depending on how your tune DTC's are setup obviously. Do you have access to your tune? Post it up if so.
Old Dec 21, 2009 | 01:57 PM
Il get the tune from my tuner in the coming few days , the car is at the shop right now and they will see whats wrong with it cuz it misfires badly and the flashing SES stops till it misfires again and thats after few seconds
tweeder
Sep 18, 2015 11:02 PM
GMCtrk
38
Aug 9, 2015 08:50 PM
Stainless Works
Aug 4, 2015 12:56 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
