Is my wideband acting right?
Old Jul 20, 2007 | 01:43 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Default Is my wideband acting right?
I havent been able to start the truck yet but I thought that when I turn the key on it would stay at whatever normal air is. Isnt normal air naturally like 14.7? It dances around if I leave the key on. Here is a video of what it does, I just want to make sure Im not going to screw up my WB when I start the truck up. This is my first WB, soon I will be the owner of HPT to start tuning this **** myself.
Old Jul 20, 2007 | 03:27 PM
thunder550's Avatar
High on diesel fumes
In open air my WB maxes out at 20.0:1. 14.7 is a mixture of air and fuel, so when there's no fuel it should read really lean.
I just watched the vid too, it seems weird that it would dance around but it looks like after it was done it settled on max lean.
Old Jul 20, 2007 | 03:47 PM
1slow01Z71's Avatar
Im an idiot, 14.7 is natural atmospheric pressure
Maybe Dewey will see this and check his DJWB out for me after he gets a battery back in his truck
Old Jul 20, 2007 | 04:42 PM
kbracing96's Avatar
My WB is full rich (9) while its in warm up mode, then it's full lean (20) after it warms up and starts reading till I start the engine. Looks like that's what yours is doing.
Old Jul 20, 2007 | 05:29 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I say normal. Mine is digital but when I key on it flashes a couple of reset codes and does the same thing. You have no fuel in the pipe so it is going to read lean off the scale.
Yes atmosheric pressure is ~14.7:1 but your sensor is reading Fuel/Air....doh!
Old Jul 20, 2007 | 05:32 PM
nonnieselman's Avatar
Mine pegs out at 20 when the engine is not running.. but at idle mine reads 15.2 and 11.2 when in boosts.
Old Jul 22, 2007 | 11:59 AM
1slow01Z71's Avatar
come on dewey I know you have DJWB where are you?
Old Jul 22, 2007 | 12:19 PM
dewmanshu's Avatar
Moderately Differentiated
Looks perfect. It will even do some other wild stuff here and there. On really cold days it won't go to the real lean side...like there is fuel laying around in the pipe or something. Looks good to me.
Old Jul 22, 2007 | 12:24 PM
1slow01Z71's Avatar
Thanks Dewey
Old Jul 22, 2007 | 12:56 PM
dewmanshu's Avatar
I was thinking after I posted...let me make a vid. FWIW the first try mine sat on 14.7 for a good 20 seconds before it did a "cycle".
oh and btw, here's hwo I got home Friday...
