Motor Swap
Old Nov 8, 2006 | 07:18 AM
Turbo 6.0's Avatar
Default Motor Swap
I have a 2004 standard cab short bed 2wd truck that came with a 4.8L and a 4l60 trans. I build a custom remote mount turbo kit that works really well. I managed to pop the 4.8L and have come across a built for boost 6.0L and a mildly built 4l65 trans. What problem am I going to run into swaping to the different trans and motor?
Old Nov 8, 2006 | 08:09 AM
thunder550's Avatar
High on diesel fumes
Motor should drop right in, I don't see any problem there. The tranny might not last very long depending on how much power you are making.
Old Nov 8, 2006 | 07:57 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Everything will bolt right up. 65E and 60E and identical in operation. The 65e just has slightly stronger parts.
Old Nov 8, 2006 | 08:24 PM
Flyer's Avatar
Since this is in the PCM section I would suggest doing some tuning and such on it. SPend some time on the VE table and you should be golden.
Old Nov 13, 2006 | 07:31 AM
slowec's Avatar
Might I suggest a used sts kit. ITS GREAT!!!
OHsixLS3
Dec 27, 2016 09:30 AM
CammedZ71
Aug 2, 2015 01:44 AM
Rwilliams85
Jul 14, 2015 04:36 PM
davis28905
Jul 8, 2015 03:20 AM
Nimoryan
Jul 5, 2015 03:50 PM
