More help needed stumble/missing
Old Jul 12, 2018 | 08:01 PM
crashmymax's Avatar
Default More help needed stumble/missing
In my never ending quest to get my truck running well and start having some fun I think im down to the last issue. The truck misses or stumbles. Its most noticeable at high speeds just cruising around at 60 the truck will start missing its a fairly healthy stumble when it happens. It happens at any speed or gear just cant feel it as much when driving slower. It does it almost every day and several time on my way to work. My tuner's comment on the problem.
It goes rich for a second then lean for a second. Your cylinder airmass even drops out and the timing dips very low just momentairly.
its like for a fraction of a second the injectors are cut off and timing falls.
So its starting to look like it might be an electrical issue. Has anyone had a similar problem? Any ideas on where to start looking? The scan attached is an older one but at about 9 minutes in start watching you will see the rpms jump for a split second. I can provide more scans if needed. Let me know what you think thanks.
This is an SD tune
Old Jul 12, 2018 | 08:08 PM
crashmymax's Avatar
Files are to big I will do a shorter scan and post it later tonight.
Old Jul 12, 2018 | 09:10 PM
crashmymax's Avatar
start watching at 5 minutes and 10 seconds it will happen a few times.
File Type: hpl
Old Jul 13, 2018 | 11:52 AM
Atomic's Avatar
I have a gauge for that
The RPM is the slowest reacting thing, if you want to see what the problem is, look at the cylinder air mass as that is what determines timing and fuel. You will notice it momentary either spikes upward or downward causing the issue.
Did you try what I suggested about the o2 sensors? Just for fun, next time you are driving, in the scanner disable closed loop fueling to see if it still does it.
Old Jul 13, 2018 | 02:24 PM
crashmymax's Avatar
Downstream sensors should be here today and I'll give it a try.
Old Jul 13, 2018 | 03:28 PM
crashmymax's Avatar
Still does with downstream sensors connected. Sent you a scan.
Old Aug 17, 2018 | 01:11 PM
crashmymax's Avatar
Still having this issue. I've tried atomics suggestions and no change. I have not had time to work on it much and needed a break from it anyway. Now I am considering a de mod and going back to stock. I would like to give another shot at figuring it out before I do. So if you have ANY suggestions tuning or mechanical let me know and I'll give it a try.
curtmgulla
May 2, 2016 01:03 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
Phatchevy
Aug 17, 2012 11:31 PM
TA/30th 1002
Aug 25, 2002 11:08 AM
ZBass28
Jan 17, 2002 10:59 AM
