Upshift/Downshift Stumble???
Old Jan 17, 2002 | 08:52 AM
ZBass28's Avatar
Default Upshift/Downshift Stumble???
Had this happen to me on the way in to work this morning.
Was cruising along behind some slow people and was just coasting, not really aware of any of the conditions but probably around 25-30mph. I went to accelerate lightly and get this odd stumble where the trans has no frickin' idea what gear it wants to be in. Within a matter of 2 seconds it shifted down, it shifted up, it shifted back down, it shifted back up, all continuously. Was quite jerky to say the least. I have noticed this before and it only seems to happen when that assinine cold weather shift pattern is in operation.
Is this something within the programming itself, or something mechanical? God I ******* hate electronic transmissions <img src="gr_images/icons/mad.gif" border="0">
Old Jan 17, 2002 | 09:13 AM
GTO Forum Director
Default Re: Upshift/Downshift Stumble???
Sounds like that PCM re-flash I was telling you about?
Questions;
Does the 5.3 come with the electronic throttle control like the 8.1's?
If so, was it (the engine) still relatively cold?
If so, you may be suffering from the "cold hesitation" issue that 8.1's seem to have when cold. There is also a PCM re-flash for this.
Old Jan 17, 2002 | 10:59 AM
ZBass28's Avatar
Lane
Pretty sure the 5.3 throttle is cable actuated. The engine was warm, not full operating temp, but probably around 180* or so and had been running for at least 10 minutes. I think I will look into that PCM reflash as this trans does seem to do weird things and they all seem to be related to kickdown/shift issues.
calsdad
Jun 14, 2023 11:07 PM
kalikid06
20
Oct 13, 2015 07:37 AM
Mossyoakglock
Aug 28, 2015 12:49 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
