missing under load, backfires, popping
Old Jul 8, 2011 | 08:03 AM
  #71
Holty's Avatar
Notorious BIG
Originally Posted by Spoolin
When's the last time you checked your oil? It'd be a PITA but if you could get a look at your intake runners...
not following you here on this one Julien?
Old Jul 8, 2011 | 09:28 AM
  #72
Atomic's Avatar
I have a gauge for that
Assuming you still have the PCV system routed to the intake, if you are having lots of blow-by you will suck up a lot of oil into the intake, and oil in the intake can cause misfiring...
Old Jul 8, 2011 | 10:30 AM
  #73
Holty's Avatar
Notorious BIG
Oh ok, i gotcha now. I have converted to a catch can setup years ago though so no pcv to the intake.
Old Jul 9, 2011 | 04:14 AM
  #74
Spoolin's Avatar
GFYS and STFU
Ahhh, bummer. It was the one thing that I saw you hadn't checked yet. Then again your plugs probably woulda shown signs of that. Back to the drawing board...I'll keep thinking.
Old Jul 9, 2011 | 04:19 AM
  #75
Spoolin's Avatar
GFYS and STFU
Ok...check your engine wiring harness, especially the loom by the drivers side tire that leads into the PCM for bite or cheweing marks. If your coils, plug wires, spark plugs and what not have all been swapped a million times than it's gotta be a faulty signal prior to that, inbetween the PCM and the coils. Shot in the dark but you don't have any vermin problems do you?
Old Jul 9, 2011 | 04:31 AM
  #76
Fastcount03's Avatar
for bite or cheweing marks. Shot in the dark but you don't have any vermin problems do you?
Or a dog??? LOL
Old Jul 9, 2011 | 07:12 AM
  #77
Gadgetized's Avatar
Another thing that was running through my mind was your injector wiring. I am not sure if it would cause your symptoms, but it would be pretty easy to accidentally switch your plugs around for #1, and #3 injectors. I would obviously check all of them to make sure.
Old Jul 18, 2011 | 02:14 PM
  #78
Holty's Avatar
Notorious BIG
OK, Julien, i have not had a chance to check the wiring into the pcm yet, but i think about this **** at least twice a day and the more i think about it the more i am leaning toward a bad/weak valve spring.
Reason (in my mind): what causes backfires? exhaust valves not closing, or not closing fast enough, right?
Old Jul 21, 2011 | 01:44 PM
  #79
OnyxSilveradoSS's Avatar
man I feel the same way about my truck...
hope you can keep motivated to figure it out.
Old Jul 27, 2011 | 07:56 PM
  #80
03sierraslt's Avatar
This thing has me stumped... Rode in it tonite, its a bad misfire for sure.
