missing under load, backfires, popping
#61
I would take it for a spin and intentionally make it skip for an extended period of time. Then check the header tubes with a non contact thermometer. Did you do anything to the truck before you parked it for the winter? Just to make sure, has this problem only happened this year?
#64
Notorious BIG
UPDATE
Put it all back together with the fresh injectors, new 2bar map sensor, and fuel filter, ANOTHER new set of plugs and guess what? Same damn thing!
I also moved the wideband bung from bank 2 (passenger side) over to bank 1 (drivers side) but have not gotten a chance to test drive it yet.
One weird thing, i drove about 30mins to a shop to have the bung welded in and the truck drove fine, did not mis, hesitate or anything unless I tried to lean into the throttle. Then it would misfire and back fire like usual. This is different than recent drives because at one point it was running so poorly it was barely drivable. This time you couldn't even tell anything was wrong until you gave it at least 50% TPS and put a load on it.
Sorry Dewey, i just have not had time to put the misfire tunes in yet because i have to setup my scanner to log misfires, current, and history, and i just have not had time to mess with it at all. If its not raining, my goal for doing that is this coming friday, i'm leaving work early.
Summary:
Truck misses under almost all circumstances....very small hint of a misfire during idle after truck is up to temp.
Misses under light load after up to temp
Misses under moderate load (60% tps) at all temps
HpTuners log shows 0 KR, no misfires, no codes, no CEL
No check engine light (and it does work)
changed plug wires twice
changed plugs 3 times
changed coil packs
injectors
O2's
checked for broken valve springs
leak down test
compression test
fuel pressure is perfect
changed MAP sensor
changed fuel filter
Someone please just steal this ******* thing
Summary:
changed coil packs
injectors
O2's
leak down test
compression test
changed MAP sensor
changed fuel filter
#65
Where are your coils mounted? I see you have a rail mounted pressure regulator. Did you move the #5 cylinder coil? The wire can hit on the regulator, and wear through. Just a thought maybe it is giving you a weak spark.
#68
Notorious BIG
THIS problem described in this post, yes it did just start after winter hibernation.
#69
Notorious BIG
I guess thats possible. When i had the coil packs all disassembled recently to paint them i did not notice any messed up wiring and i was looking over the wiring pretty closely. i check again right near the fpr though. thx!
