Message Center Help!!! Security Light
Old Apr 23, 2008 | 07:13 PM
dmoss69's Avatar
Banned
Default Message Center Help!!! Security Light
I've changed out the engine, PCM, and wiring harness out of an 02 truck and put it in my 93, everything works fine.....
When I turn off the truck, the message center keeps flashing the yellow security light, and will kill my battery. The only way I can get it to stop is to unplug the instrument cluster wiring from the top of the instrument cluster, plug it back up, and it works.
As far as the message center, I really don't care about it, if I can just either get the security light to stop OR turn the message center off all together, that'll be fine to, as long as I still have all my gauges working.
I have tunercats, and I've taken the VAT's off, so it's not like it is going to leave me stranded from the VAT's issues.
Ideas?
Thanks
David
Old Apr 26, 2008 | 07:40 PM
Wide Open's Avatar
You could disconnect the small ribbon cable form the Message Center itself and see if that resolves your battery drain issues. It will save you from disconnecting the main harness from the cluster.
Old May 1, 2008 | 07:41 AM
dmoss69's Avatar
Banned
Default tape
Thank you, I'll try that this evening!
Old May 1, 2008 | 07:45 AM
TouchOfEvil04's Avatar
Not sure what tunercats is but in hptuners you turn off the code for the f- generator terminal.
also you can try doin a security relearn on it....
Old May 1, 2008 | 10:04 AM
fastnblu's Avatar
TunerCat is his programming; just like most of us use HPTuners or EFIlive. Another brand.
Old May 1, 2008 | 10:26 AM
dewmanshu's Avatar
Moderately Differentiated
How long are you leaving your truck sit that a flashing dash light would kill the battery?
Go5.3tt06
May 15, 2016 12:15 PM
carid
Oct 28, 2015 08:24 AM
kalikid06
20
Oct 13, 2015 07:37 AM
SlvrSierra4.8
Oct 1, 2015 09:42 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
