Mass air flow rate-need help-autotap
Old May 15, 2006 | 01:03 PM
SpdFrk's Avatar
Default Mass air flow rate-need help-autotap
the description of mass air flow rate says scan tool range is 0.0-655 gm/s. but when you select it to log the data it reads the numbers in Ib/min. is there a way to change the way it reads the data or is there a math conversion to convert from Ib/min to gm/s? i am using version 2.05 on a 2004 Chevrolet Silverado Pickup. thanks for any help.
Old May 15, 2006 | 03:23 PM
Mort's Avatar
Cool
Check out Online Conversion to figure out all sorts of interesting conversions.
1 pound/minute = 7.559 866 667 gram/second
Autotap should have a place to convert to metric readings from US if you look around the menus. Check out help it should tell you how to switch modes.
zraffz
Sep 20, 2015 08:25 PM
TAPyvehc93
Sep 17, 2015 10:10 AM
Rockrz
Sep 13, 2015 12:22 AM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
