Need idle tuning help..
I installed a cam last week "cammotion 223/218 .576/.564 115+4" and i almost got it tuned.. It idles fine when i crank it up but, when i come to a stop from cruising it wants to stall.. I got my idle set at 650 rpm.. I'm using HP Tuners to tune it with..
ok, both of you try this, post 18
https://www.performancetrucks.net/fo...11#post3333111
Chris, yours should be the same as I described cuz your using EFIlive, and Speedy, yours should be similar, I'm not a 100% sure how HPT does this, but should be close.
Bingo! Did what you said and it's doing great now!
Got my avg RAFIG down to like 0.06 g/sec and my avg RAFPN to 0 exactly after idling for 4-5 minutes each in park and in gear. Drives like a charm now! They were both maxed at 1.50 when I started, hence my problems.
Idle is set at 725 RPM. I get a slight drop when I shift from P to D since it kicks into gear right away, no drop when I go from P to R because there is the 1-second delay before it drops into gear and the IAC has time to compensate.
The bouncing RPM when coasting slow in N is gone too. Sticks right around 725.
BTW...I went from mid-upper 7s in the In Gear desired airflow to 12's. Big jump
This Nick Williams TB is damn noisy too when I'm idling in gear. I can hear it inside the cab with windows up and music down low. I guess you can really say my truck sucks now
noproblems209
Aug 10, 2015 06:57 PM
Suburbazine
Aug 9, 2015 01:17 AM
GMCtrk
Jul 17, 2015 06:39 PM
GreyChevy
Jul 7, 2015 08:57 PM
