MAP reading boost cranking
Old Apr 4, 2013 | 05:37 PM
yzriders182's Avatar
Default MAP reading boost cranking
So I have COS3 loaded in with efilive and a 2 bar map. Its a SD tune and I just finished the build. Its a twin turbo 5.3l Silverado.
Using the Efilive scan tool monitoring the MAP sensor when cranking and when it fires it is reading 115kpa-120kpa. and never goes below 105kpa. I have the MAP scaled to 190 in the tune.
The truck will only run for about 2-8 seconds then stall out. I think it has something to do with this.
Any ideas?
Thanks
Old Apr 4, 2013 | 05:43 PM
GMCtrk's Avatar
Did you scale the MAP appropriately compared to the 1 bar or did you just put in the set value of 190?
My scalar had to be set to 198 to read the same as the factory 1 bar.
Old Apr 4, 2013 | 05:48 PM
Atomic's Avatar
I have a gauge for that
What does the sensor read Key On Engine Off?
Old Apr 4, 2013 | 05:56 PM
Key on engine off it reads about 105kpa.
No I didn't scale the MAP compared to the 1 bar. How do you do that. I hope I still have the stock one...
Old Apr 4, 2013 | 05:58 PM
Atomic's Avatar
What do you have the offset set to?
Old Apr 4, 2013 | 06:04 PM
It was set at 10
chopperloco
Jul 10, 2016 10:45 PM
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
GreyChevy
Jul 7, 2015 08:57 PM
