MAF tuning for turbo
Old Oct 22, 2006 | 03:01 PM
adam1803's Avatar
Default MAF tuning for turbo
I just swapped a 6.0 in place of my 4.8 and kept the same turbo system. Can i use the same values from my MAF tables i had with the 4.8 or will it be completely different for the 6.0? Thanks
Old Oct 23, 2006 | 05:38 AM
Whippled 496's Avatar
I would imagein that 6.0 will be sucking more air than the 4.8 did. So i would guess you would need to retune.
Old Oct 23, 2006 | 08:54 AM
Wilde Racing's Avatar
How do I change this text
You will need to retune for sure.
Old Oct 23, 2006 | 11:03 AM
adam1803's Avatar
i kinda figured that, but it would be sweet if i didn't have to and just adjust the pe tables.
Old Oct 23, 2006 | 11:51 AM
dewmanshu's Avatar
Moderately Differentiated
where you using stock 4.8 values before? or did ya tune the maf table already?
i ask cuz if you were fine with stock 4.8 maf table, just download a 6.0 stock tune and use the 6.0 stock table.
Old Oct 23, 2006 | 01:07 PM
dc_justin's Avatar
Hello Dave
You'll be just fine running the stock MAF calibration table. Compare a 4.8L tune to a 6.0L tune (of the same year), and you'll see that the MAF calibration is identical.
The MAF measures incoming air, completely independent of engine size. 300g/sec of incoming air is 300g/sec, regardless of whether its on a 4.8L at 6000rpms or a 6.0L at 3/4 throttle at 4500. The important piece of the puzzle to have correct with a change of this type is your injector flow rate, as MAF calibration relies heavily on IFR to provide accurate fueling.
With a change from 4.8 to 6.0, the VE will definitely need to be scaled up a bit. Cranking VE, Afterstart enrichment, idle airflow and a number of other tables will also need to be changed. You'd be best off taking a stock 6.0L tune and startign your re-tuning with it.
Old Oct 24, 2006 | 08:31 PM
adam1803's Avatar
I already have a stock 6.0 tune in it, i was thinking of just pasting the values from my 4.8 turbo tune into the stock 6.0 tune and adjust the other tables accordingly for the turbo.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Ls3silverado
Jul 31, 2015 04:22 PM
V-seriesTech
Jul 28, 2015 12:28 PM
oharajo
Jul 18, 2015 09:24 PM
