MAF sensor/speed density question
Old Jan 14, 2008 | 10:38 AM
t_thall's Avatar
Default MAF sensor/speed density question
Just built a twin turbo setup on a 5.3l chev truck and am using Hp Tuners to tune it. i was told that when using 2 bar speed density you remove the MAF sensor, but i see that i have no IAT reading once i do so. Is there a different IAT sensor i can wire in or do i have to mount the MAF sensor into my piping?
Old Jan 14, 2008 | 10:41 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Move the IAT sensor only.
Old Jan 14, 2008 | 10:54 AM
BlackGMC's Avatar
Resident Retard
Maybe these will help!
https://www.performancetrucks.net/fo...&highlight=IAT
Old Jan 14, 2008 | 05:34 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Ya, a 2002 Camaro iat will work. You can get the connector, sensor and grommet from the dealer. You'll need to cut the last two wires on the maf and connect them to the new iat wires.
Old Jan 14, 2008 | 05:58 PM
HD6.0l's Avatar
Banned
Like this :
GM part numbers from a c5 Fbody
air temp sensor 12160244
sensor grommet 24504388
Sensor plug : http://www.eficonnection.com/eficonn..._pigtails.aspx
Old Jan 14, 2008 | 06:02 PM
t_thall's Avatar
Thanks a lot!
Old Jan 15, 2008 | 09:28 AM
t_thall's Avatar
Which two MAF wires?
Old Jan 15, 2008 | 10:56 AM
Mort's Avatar
Black and Tan.
Old Mar 9, 2008 | 11:43 AM
D-GTO's Avatar
If it is the same as the one I used on my GTO then Casper Electronics has an extension / splitter harness that doesn't require any cutting of wires
Old Mar 9, 2008 | 12:23 PM
dirt track racer 81's Avatar
you could just pull it out of the maf..be alot cheaper..just drill a small hole and put it in there
