maf screen
Old Jun 18, 2006 | 12:36 AM
Dirty Dave's Avatar
Default maf screen
Can I remove the screen in my maf or would that mess with the calibration? Every once in a while my maf gets blown off when on high boost. Im using a 5/16 socket to tighten the clamp instead of a screwdriver. I plan on getting T clamps in the future but that screen looks like a bad restriction especially at 15psi.
Old Jun 18, 2006 | 07:23 AM
TIM Z's Avatar
11 sec. Truck Mod
It will mess up your tune, I'd try the T bolts clamps, I had a friggen nightmare trying to tune my screenless MAF. Or you could go Speed density tune and lose the MAF.
Old Jun 18, 2006 | 07:59 AM
Dirty Dave's Avatar
I did a search using maf screen and it looks like you are correct. I plan to get a 2 bar sd tune soon.
Old Jun 18, 2006 | 09:22 AM
03NHSilvy's Avatar
what is the benefit of going SD? I was told that a SD setup is harder to tune, just curious.
Old Jun 18, 2006 | 10:45 PM
zippy's Avatar
Are you maxing the maf's numbers while logging?
Old Jun 18, 2006 | 10:59 PM
Yelo's Avatar
At 15psi you should REALLY be running in SD mode....you've got to be REALLY close to maxing the MAF. HPTuners offers custom 2-Bar SD OS's that make tuning in SD mode alot easier than trying to do it on a stock OS
Old Jun 18, 2006 | 11:44 PM
moregrip's Avatar
what a rush!
it's my understanding the only reason the screen is there on our trucks is because the route from the MAF to the TB is not direct, so the screen aids airflow by straightening it out. If we had a direct route I imagine our MAF would be screenless as well, and yes it does slightly reduce airflow.
Old Jun 19, 2006 | 03:23 PM
TIM Z's Avatar
11 sec. Truck Mod
what is the max value for the MAF or what is considered close to max?
Old Jun 19, 2006 | 03:36 PM
Yelo's Avatar
12000hz is max MAF
Old Jun 19, 2006 | 05:14 PM
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by Yelo
12000hz is max MAF
thanks, im still trying to learn some of the values on mt interceptor gauge and how they affect my tuning, such as watching the MAF value @ a certain rpm while the W/B is reading lean and bieng able to add fuel at that precise point in the table instead of throwing more fuel over a wider area and getting it too rich where it doesnt need it. I need a course on tuning
