MAF Maxed out?
Old Oct 5, 2005 | 08:02 AM
LBSBLOWN's Avatar
Default MAF Maxed out?
This is a 2005 5.3L with a Radix Supercharger & a 3.0 pulley.
At 6300rpm I maxed out the MAF @ 454.39 g/sec, I noticed that the MAF Airflow vs. output frequency table only goes to 453.69 @ 12000hz.
What exactly happens when the MAF is maxed?
what does the computer do?
Can I adjust the g/sec @ 12000hz to 455.00?
And if i do what will that accomplish?
BTW it appears that the Throttle gets pulled back when the MAF gets Maxed.
Old Oct 5, 2005 | 09:41 AM
desTRUCKtive's Avatar
I believe the computer will jump into speed density. I know that a couple of people have jumped to speed density when the Mass Air can no longer support it.
Old Oct 5, 2005 | 09:47 AM
JERRY2500's Avatar
14 Second Truck Club
Just disable the maf and tune it. Maf is a pita to tune. And the truck runs much better without it.
Old Oct 7, 2005 | 10:48 AM
I would like to try this. How exactly do you disable the MAF? I have LS1 Edit.
Old Oct 7, 2005 | 03:04 PM
Its not quite that simple. With FI, I would get a 2 bar MAP and find someone that can do a speed density tune on it. Expect to pay more, but it is the way to go if you have the $.
On trucks with the IAT built into the MAF, you will have to get an IAT from an f-body or something similar and wire it up if you want to take the MAF out.
Old Oct 7, 2005 | 03:59 PM
So just unplugging it is all you have to do and it makes all that power. I know it sounds mean that way cause I've forgot to plug it in several times. Now when I'm sitting in a parking lot full of racers I'll unplug it and scare everyone away. Never thought to race with it that way. Thanks for the info dude.
Old Oct 7, 2005 | 04:34 PM
With HPtuners you unplug the MAF dissable the SES code and tune the Volumec effeciancy tables.
Old Oct 7, 2005 | 10:02 PM
greentahoe's Avatar
Ive heard that this is a quick way to smoke an engine if you dont have the aforementioned 2 or 3 Bar MAP sensor. Are you running SD? Did you tune it? Id love to get rid of the MAF.
lucas287
31
Jan 12, 2021 06:18 AM
JordanH
Oct 3, 2015 03:59 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
2plus2
Sep 13, 2015 07:17 PM
JordanH
Sep 12, 2015 12:02 AM
