Lost a bunch of histograms on HP Tuners
Old Jan 20, 2015 | 01:19 PM
Wyttrash96's Avatar
I hate my cats
Default Lost a bunch of histograms on HP Tuners
I've been away from tuning for a long time. I installed headers so now it's necessary. When I opened up my program yesterday I first got a warning screen that said I had a beta version. I don't remember if I used to get that screen or not. Now trying to tune LTFTs and STFTs, and I can't cause I only have numbers 1 and 2 in the histogram toolbar. All I've got is timing advance and knock retard. Zuh?
My laptop definitely needs a visit to the computer shop for a long overdue virus scan , do I need to reload my program? I've got the MPVI Pro version, if that makes any difference. Thanks!
Owen
Old Jan 20, 2015 | 02:07 PM
03sierraslt's Avatar
What config are you using?
Old Jan 20, 2015 | 02:11 PM
Sounds like you are trying to tune a vehicle with a virtual VE table since the FT histograms are based on normal VE tables but since you don't give so much as a clue to the vehicle year and type how the hell can anyone know.
And if you have to take your computer to a shop for a virus scan should you really be trying to tune? While it is there you should also ask them to install the latest version of HP Tuners.
Old Jan 20, 2015 | 09:33 PM
Wyttrash96's Avatar
I hate my cats
Ummmm...I dunno? I'm very very green at this. What would be a possible answer to that question?
Old Jan 20, 2015 | 09:45 PM
Wyttrash96's Avatar
I hate my cats
Nope, not a virtual VE table. It's an L76 in a 2008 Sierra Vortec Max. I did some pissing with the transmission, AFM, spark and VE tables years ago but 3 jobs and a family have cut into the hot rodding schedule. I've gotta relearn everything now. That's why I said I lost the histograms instead of asking where they'd be in the first place.
I'm using the same MPVI Pro program I bought back in 08 and used on my 99 Sierra LM7 and 97 Grand Prix GTP. How old of a vehicle would have a virtual VE table? Thanks for any help I can get here fellas.
Old Jan 20, 2015 | 10:43 PM
gamble686's Avatar
Things have changed a fair bit from a 99pcm to the 08pcm. It may very we'll have Virtual VE. I know my brother in laws 07 vette had virtual VE. I haven't tuned any newer trucks yet.
Old Jan 21, 2015 | 04:16 AM
Have you ever tuned on the 08 before?
Old Jan 21, 2015 | 08:02 AM
Wyttrash96's Avatar
I hate my cats
I've definitely done a bit of tuning in this before. I thought I had played around with the VE tables, but now I'm second guessing myself. Maybe I'm thinking of one of my old vehicles? Would this truck have a virtual VE table? If so how would I tune the trims now that I have headers?
Old Feb 16, 2016 | 09:16 PM
HOUSEofI3()()$T's Avatar
It is virtual VE. Im a newbie and have been trying to get things figured out. If its just headers and probably not SD only. You could mess with timing and PE tables. Should even worry about VE or VVE IMO...
Old Mar 2, 2016 | 07:16 PM
LIL6BT's Avatar
You need to tune the VVE and the MAF.
Pick which one you want to tune first.
If you are tuning the VVE then you will need to fail the MAF sensor and set the MAF codes to MIL on 1st. That way the MAF is not providing any fueling info to the ECM.
Also make sure not to log the MAF sensor when tuning VE/VVE or it will throw off the numbers.
If you want to tune MAF first then set your dynamic airflow limits below idle speed and log your MAF vs fuel trims and work from there.
Pick one and get the fuel trims in line, then do the other. I usually do one, then the other, then go back and hit the first one again to make sure I'm all good.
I have kept this very broad and very basic. But, if what I have said makes sense then you can move forward. If what I have said sounds like gibberish, then you should read up for a while to make sure you have sound practices and you aren't going to do major damage to your engine.
And do not shortcut it and skip tuning the VE/VVE.
Now that HPTuners has VVE editing capability built into the software, there are no excuses to half way tune one.
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Chevy305
Sep 28, 2015 09:21 PM
Raiderjim
Sep 28, 2015 10:37 AM
bisqikss
Sep 27, 2015 09:40 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
