locking converter with a switch...
Old Mar 26, 2014 | 11:56 PM
Noah Burns's Avatar
Default locking converter with a switch...
is this even possible? I've heard people talk about it but never seen it, or heard how it would be done.
Old Mar 27, 2014 | 12:05 AM
TCC solenoid is powered inside the trans pan all the pcm does is supply a ground to the solenoid.
So toggle switch one side to ground and other side to tcc solenoid and TCC pwm solenoid = full control over TCC lock up
Old Mar 27, 2014 | 08:58 AM
BigBlock90's Avatar
i run a 4l80e in my 454ss truck and i have my lockup on a toggle switch. just ground the signal wire to your lockup when you want and cruise unlocked whenever...
Old Mar 27, 2014 | 09:56 AM
Choda's Avatar
... Sounds like an easy way to make a glory pass on the dyno...
Old Mar 28, 2014 | 12:56 AM
Suburbazine's Avatar
Been there, tried to do that, didn't work.
Old Mar 28, 2014 | 09:10 AM
BigBlock90's Avatar
i couldnt afford an $800 controller for the 4l80e on my carbed motor so i had to settle for a Jakes manual control box and wire it in......
Old Mar 28, 2014 | 01:31 PM
Choda's Avatar
Didnt make more power or didnt lock the tc?
Old Mar 30, 2014 | 03:22 AM
Couldn't convince it to stay locked without upshifting unexpectedly during the pull. Think tire-spinning 2-3 shift (in lockup at WOT) on top of a Dynojet single-roller dyno, held back only by 4 safety straps.
As far as the power, yes, it made a lot more (~100hp) locked up instead of unlocked. I say 400rwhp...but the real number is probably a little higher than that and a little lower than where the graph put it. It's just a heavy truck though, it's not like it has ever outrun a Ferrari at sub-120 speeds(if this happened, it was in Mexico on some forgotten dusty road near the border).
Old Mar 30, 2014 | 08:57 AM
thewrx's Avatar
Sounds like asking for trouble if you dont know know what you are doing, also a triple disc would be a must for wot pulls.
Old Mar 30, 2014 | 11:22 AM
bowtiewrencher's Avatar
Can you program the TC to lock up with HP tuners? And is this something that would be beneficial in sled pulling?
