LED/turn signal issue
Old Mar 21, 2016 | 12:30 PM
lopy6oh's Avatar
Default LED/turn signal issue
NNBS. I just cleared my headlights and figured it'd be a good time to switch out the bulbs to LED. I installed resistors as well on both the top and bottom (parking light/turn signal) LEDs to avoid fast blinking. (Wasn't sure if the top ones were necessary since I didn't think they were turn signals but the diagram I found used resistors on both). Well now on the passenger side the top and bottom lights blink and on the driver side only the bottom blinks. Any ideas on what I could have done differently to them? I've rechecked all the wiring and they appear to be wired the same. They all come on, just the top one on the passenger side doesn't brighten like the rest with the turn signal engaged.
Old Mar 21, 2016 | 12:34 PM
lopy6oh's Avatar
Here's the diagram I used
Old Mar 22, 2016 | 04:39 AM
lopy6oh's Avatar
Bump......
Old Mar 22, 2016 | 12:15 PM
Atomic's Avatar
I have a gauge for that
Do you have the LED backwards by chance?
Old Mar 22, 2016 | 12:22 PM
lopy6oh's Avatar
I don't believe so because I had another one backwards and it wouldn't come on at all
Old Mar 22, 2016 | 12:31 PM
Atomic's Avatar
Oh so it comes on it is just dim? Make sure its not bad itself, put 12v directly to it and see if its full brightness. Use a volt meter to measure the voltage there to make sure its getting full power.
Old Mar 22, 2016 | 12:51 PM
lopy6oh's Avatar
No it comes on bright. It just doesn't brighten/flash when the turn signal comes on. It's the running light (upper light) so I don't even know if it's supposed to flash with the turn signal light (lower light), but the passenger side is so either the driver side is suppose to be flashing or the passenger side shouldn't be flashing
Old Mar 23, 2016 | 10:11 AM
someotherguy's Avatar
NNBS - do those trucks flash through a computer module like the BCM instead of a traditional flasher unit? If not, then I'd look for an LED-compatible flasher. I don't have a ton of NNBS experience (just a few work trucks) so I don't know; tried looking up the flasher unit online and couldn't find one.
Have you tried it without the resistors at all? At least that way you can be sure you have the LED's installed correctly and that they are working. They might flash fast, or might even flash normally without resistors needed - all our work trucks (2009-2010's) were 100% fine loaded with LED tails and no modifications needed, but they still had the regular incandescent front signals.
My hungover brain isn't following your explanation completely but it sounds a little bit like the way the resistors are wired up may be causing your issue.
Richard
Old Mar 25, 2016 | 04:45 PM
lopy6oh's Avatar
Richard
Yeah I'm pretty sure it is controlled by the bcm. I took the resistors of just now and same deal except the one bulb just hyper flashes
Old Mar 25, 2016 | 04:54 PM
lopy6oh's Avatar
Looks like autozone sold me a bad LED. Swapped them and vice versa. Sob! At least it's an easy fix
BlackGMC
Mar 21, 2016 01:39 PM
Trey Hanna
Mar 20, 2016 12:52 PM
DopdBrd
Mar 19, 2016 04:35 PM
Big Chuk
Mar 19, 2016 01:42 PM
DAH32
Mar 18, 2016 02:12 PM
