Lean spike at shifts
Old Jun 1, 2007 | 09:14 AM
dewmanshu's Avatar
Moderately Differentiated
Default Lean spike at shifts
Since the 60# inj swap I have this lean spike at WOT shifts. I am SD so...
5600rpm/165kpa I go 8ish% lean
6000rpm/160kpa I go 5% lean
yeah yeah, add to those areas right. Well, I keep adding and it stays about 5% lean in the shifts. At the track on 5/6/2007 what I thought was a clogged meth nozzle, turns out wasn't.
My VE table is 135% at 6K/160kpa and 133% at 5600/165kpa
aaaaand the cells before that are 129% at 5600/160kpa and 121%(this should probably be higher, just have never hit it) at 5200/165kpa.
I mention these numbers cuz that's a huge difference, a large incline in the table at those cells. Those numbers are with me adding 5% this morning. I am guessing even with that 5% increase it won't fix it. It didn't help at the track a month ago.
Soooooo, my question is WTF? Mechanical? It holds the 160kpa and 165kpa spots pretty well, so it doesn't appear I was in belt slip and then not. (or crank slip for that matter) I wanna say a WB malfunction, but only at shifts?
Old Jun 1, 2007 | 09:21 AM
Holty's Avatar
Notorious BIG
this is very interesting. is this the scan you ran your 12.0 1/4? where you juicin' at the time of this lean spike? it happens with or without meth right? very strange...
Old Jun 1, 2007 | 09:23 AM
Wilde Racing's Avatar
How do I change this text
I ran into this once when I started tunning, My v.e tabble looked like a nice hill with a huge hole in the top, I can't rember what I did, but I believe that is when I started playing with not relying on the p.e and b.e tabbles so much and tune more with the v.e....
I'll dig up some of my old tunes....
Old Jun 1, 2007 | 09:29 AM
dewmanshu's Avatar
nope. this scan was this morning. No meth, no nitrous. It does this with meth and nitrous as well.
Old Jun 1, 2007 | 09:33 AM
dewmanshu's Avatar
as you know, it's using the BE table.
Old Jun 1, 2007 | 09:40 AM
dewmanshu's Avatar
Here is the 12.02 run...
Old Jun 1, 2007 | 10:38 AM
jconner111's Avatar
the tables dont lie, but be sure to use real time...maybe 10% more in timing???may sound silly, but....
Old Jun 1, 2007 | 10:39 AM
jconner111's Avatar
AND this motor should take 21-24 degrees advance at WOT
Old Jun 1, 2007 | 10:44 AM
dewmanshu's Avatar
no way w/o meth could i get 24* out of it having the radix on there. It'll start tiny kr at 20*.
if the tables don't lie, then shouldn't it go lean in the 1/2 shift (pretty much same cells)?
Old Jun 1, 2007 | 11:56 AM
KySilverado's Avatar
Dropping fuel pressure deserves a look.
