LC-1 Install Help
Old Sep 21, 2006 | 09:16 AM
Whippled 496's Avatar
Originally Posted by Blown02Sierra
thanks for all the help! So do i need to ground the system and analog grounds to the chassis as well as plug them into the EFILive blackbox logging box?
yes
Whippled496, is the actual box to the wideband inside your console, or is that hanging underneath?
It hangs securely underneath.
And when you say u punched a hole, you actually drilled through the floorboard? Where is the closest grommet?
Yes, its about a 5/8" hole and i used a rubber grommet and some RTV sealant. Dont think there are any other holes or grommets in that area.
Is it possible to have the lc-1 box inside of the cab w/o extending the o2 wires?
I dont think so.
Do you all suggest permanent install or temp?
I did both, i permanently installed the wiring under the truck and under the console, but i temped up the power so i can just unplug it when im not using it. I did that with the cigarrette plug.
Those w/o an xd1, do you use the normally open switch and led included in the package for your open air cal?
I used the analog 1 output, and i wired up the LED so i could tell if there were any errors during the setup.
I tried plugging the serial cable into my pc and could not get a reading. Does the lc-1 need any sort of power to be programmed?
Yes, you need 12v to it and make sure you have the mini jacks hooked up correct with the one terminator plug.
When installed, are the plugs(forgot what they're called) plugged or open? (ie, do i put a terminator plug in them?)
I kept them out, one is for the terminator, the other is for the serial cable. Obviously your not going to keep your serial cable hooked up, and I also left the terminator plug out as well.
Old Sep 25, 2006 | 05:06 AM
Blown02Sierra's Avatar
wow, thanks for all the help.
One more ?. have any of you used the usb to serial adapter thingy? Is it just a direct wire or does it use a converter in between? Any pics?
Old Sep 25, 2006 | 05:50 AM
Yes, its just a direct cable. DB9 to USB.
Old Sep 25, 2006 | 06:40 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Get a BELKIN. The older one I had wouldnt link up. The new one should come with a driver CD rom.
Old Sep 25, 2006 | 04:04 PM
Well, i tried to find a direct cable at radio shack and the all knowing radio shack employee tried to get all high and mighty w/ me saying that it wont work and theres no such thing and they are two different technologies, so i told him that i know that they are two different technologies, but im using a wideband controller w/ a (radio thingy? forgot what its called) plug and it already has that **** built in and says so in the manual but he kept cutting me off saying yeah, sure, right. Fu(k radio shack. Im going to fry's.
Old Sep 25, 2006 | 04:39 PM
1SlowHoe's Avatar
The one that didnt work came from Radio Shack. They are not too bright up there.
http://cgi.ebay.com/BELKIN-USB-to-SE...QQcmdZViewItem
Old Sep 25, 2006 | 05:33 PM
in summary, this is surely the truth.
Old Sep 25, 2006 | 08:00 PM
MrXerox's Avatar
NEW SLOGAN:
"Radio Shack..you've got questions, we have blank stares"
LCHEE
Oct 24, 2020 04:10 PM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
