Laptop turns itself off while logging...
Anyone ever seen this? My ASUS G75VW was logging data Sunday and then there was a faint pop and it went dead. I mean turned off immediately....not went to sleep. Brought it home and plugged it into the charger and powered back up. It seemed to be ok and did everything as normal. This evening it did the same thing. Logging for a shorter time though. Outside of HPT scanner it seems to be fine while plugged into the charger. Have not tried to do anything other than log scanner data with it unplugged.
Never had an issue out of this machine before....
At your home, if you unplug it, does it suddenly die also? Check the USB ports if something was connected, I had a machine with a short in the USB port that shorted it out, it was finicky.
teesee150
05-01-2009 04:13 PM
LSUxBlake
11
11-19-2008 07:08 PM
slowprocess
08-02-2005 11:45 AM
nativetexan
07-25-2005 10:08 PM
