KR at WOT
Old Apr 16, 2007 | 10:38 PM
anarchyracing101's Avatar
Default KR at WOT
I have a Nelson Tune for my mods below, mainly the cam/headers. How much performance could I be losing if im seeing KR as high as 8.0 at WOT. I know KR is certainly not a good thing to see at any time. I like my Nelson Tune and this is my second cam Ive tuned for from Allen, the last one was the MS4 and I never saw any KR anywhere in the RPMs.
Old Apr 16, 2007 | 10:44 PM
RandomHero's Avatar
8 is pretty high. I can't really say how much power you're losing but that is definantly a pretty good spike.
You do have a 01-02 pcm right? Also you did do a crank relearn correct?
I was seeing tons of KR before I did a crank relearn and then it all went away.
Old Apr 16, 2007 | 10:48 PM
I do have an 01-02 pcm. Interesting, I never even did a crank relearn after the recent cam swap, because it didnt appear i needed one after the MS4 cam...just plugged in the pcm and cranked over.. so a crank relearn could clear up all that KR?
Old Apr 16, 2007 | 10:51 PM
RandomHero's Avatar
Not saying it will for sure but when I swapped to mine it was pulling timing like crazy and I was seeing around 6* KR. I did a crank relearn and BOOM it felt like the truck gained 30 rwhp
Old Apr 16, 2007 | 11:04 PM
im on my way down to the garage..... ill be back with results!
Old Apr 17, 2007 | 07:25 AM
Rhino79's Avatar
9 Second Club
Yeah, 4* is like the factory max for knock retard, so he probably changed that to 8* max. Your losing a lot of power with that much timing being pulled.
Old Apr 17, 2007 | 10:19 AM
dc_justin's Avatar
Hello Dave
I want to say that all of the gas tunes I've seen have KR max set to 8* in PE mode, so at WOT, that's pretty much normal.
As to whether or not you're losing power from the timing being pulled... Maybe, maybe not. If the timing is excessively advanced, then pulling 8* may still leave you at a point where peak cylinder pressure is occuring. It's certainly not the most efficient before the spike picks up, but it may or may not be after the KR spike occurs.
Old Apr 17, 2007 | 03:05 PM
I couldnt get a hold of the buddy of mine with the obd2. What kinda obd2 or tec2 can i get inexpensively to do the crank relearn? Im sure ill need it in the future.
Old Apr 17, 2007 | 03:32 PM
RandomHero's Avatar
HpTuners or EFILive
Old Apr 17, 2007 | 05:41 PM
Country Boy's Avatar
Senior Member
Ive built 3 motors and swapped 4 cams and have never done a crank relearn. Never a problem yet.
8*s is a lot of timing but like dc said, it wont matter if the timing is advanced too much anyways. I would say that you are losing power though.
