KR in 2nd?!?
Old Jul 19, 2006 | 10:36 PM
nonnieselman's Avatar
Default KR in 2nd?!?
Hey guys,,, got a ?..
Im gettin KR in 2nd gear but not 1st..... im thinkin its my 00 pcm.. but my friends 04 gets KR also in 2nd but not 1st.. but he is running 87oct , im running 93oct...
Any suggestions.. or tips?
Old Jul 19, 2006 | 10:37 PM
chrisj6's Avatar
Main test would be to take that timing out and see if it stays there, then if your fueling is all correct I would say its false knock. You could also try adding some race gas and see if the KR stays.
Chris
Old Jul 20, 2006 | 12:19 AM
dc_justin's Avatar
Hello Dave
Mind posting up a log file showing this?
Old Jul 20, 2006 | 06:18 AM
dewmanshu's Avatar
Moderately Differentiated
notice your efi live, how much have you screwed with timing? ve tuning? pe?
Old Jul 20, 2006 | 12:27 PM
goshawk23's Avatar
Truck addict
it's my timing tables he's running. i never see kr. i'm thinking it's false but we'll see.
Old Jul 20, 2006 | 12:39 PM
Moddoo's Avatar
Makes sense to me, the load on the engine is higher in 2nd.
Old Jul 20, 2006 | 02:41 PM
thunder550's Avatar
High on diesel fumes
I see more KR in 2nd than anywhere else.
Old Jul 20, 2006 | 09:22 PM
Wilde Racing's Avatar
How do I change this text
Back in the days I wasn't running 2 bar I'd see all my kr right after 1>2 shift, due to the engine leaning out slightly.
Old Jul 21, 2006 | 02:28 PM
Yelo's Avatar
Relatively speaking there's hardly any load on the engine in 1st gear compared to 2nd gear...if you're only seeing KR in 2nd I'd lean towards believing it's actually real (false KR tends to show up in all gears)
Old Jul 22, 2006 | 07:04 PM
dewmanshu's Avatar
Hey guys, a long time ago Flyer told me to change the knock fast attack setting to .75 to stop the long drag on of knock. I didn't realize then how helpful it would be in diagnosing real/false knock but it works pretty good. If it's real knock, it will look real choppy onthe "graph chart". Instead fo quick blip. Granted the quick blips can still be real, but you won't get held down when there isn't knock with this setting. Like Yelo says, false tends to show up in the same places in all gears.
Just a helpful note. I hate looking at that graph and seeing 2* of kr then it taper down for the next 2 to 3 seconds.
