Knock and O2 sensors?
Old Apr 29, 2012 | 08:29 PM
custm2500's Avatar
Ph.D. in HUBRIS
Default Knock and O2 sensors?
I see plenty of guys not running knock sensors and/or 02s and I was wondering if I should run them? I have a large cam, running 110 fuel, and have a wideband.
I am guessing with large cams you get false knock? That is just an assumption and trying to determine if I need them or not.
P.S. Do I need to install the knock sensor if I am not hooking them up? Meaning will the hole they mount in leak if I don't install them?
Old Apr 29, 2012 | 09:37 PM
batboy's Avatar
11 Second Club
I would keep the knock sensors. They do a critical job in protecting your motor. You also definitely need the front O2 sensors. The rear O2 sensors are a different story, they can be eliminated, no problem.
Old Apr 29, 2012 | 09:45 PM
Area47's Avatar
02's can be removed if you running SD. knock sensors. i wouldn't. i leave them turned on in the tune and plugged in on the motor side. regardless of power. 200-1000+
Old Apr 29, 2012 | 09:56 PM
FILE's Avatar
You still want to run CL on a SD tune.
Old Apr 29, 2012 | 10:01 PM
Area47's Avatar
yes and no. depends on what the vehicle is being used for. key word that post was "if"
Old Apr 29, 2012 | 10:14 PM
La Blue 05's Avatar
keep your knock sensors just desentisize them a lil so they wont give off false knock, keep your 02s for safety reasons
Old Apr 29, 2012 | 10:15 PM
2007chevy5.3l's Avatar
If your worried about getting alot of false knock you can desensitize them to a degree to try and help determine what is real and what isnt
La blue beat me to it haha!
Old Apr 29, 2012 | 11:45 PM
La Blue 05's Avatar
Lol..took you a while
Old Apr 30, 2012 | 06:27 AM
custm2500's Avatar
Ph.D. in HUBRIS
Ok. I will install them.
Why is it that people don't run the knock sensors sometimes?
