Knock and O2 sensors?
I see plenty of guys not running knock sensors and/or 02s and I was wondering if I should run them? I have a large cam, running 110 fuel, and have a wideband.
I am guessing with large cams you get false knock? That is just an assumption and trying to determine if I need them or not. P.S. Do I need to install the knock sensor if I am not hooking them up? Meaning will the hole they mount in leak if I don't install them? |
I would keep the knock sensors. They do a critical job in protecting your motor. You also definitely need the front O2 sensors. The rear O2 sensors are a different story, they can be eliminated, no problem.
02's can be removed if you running SD. knock sensors. i wouldn't. i leave them turned on in the tune and plugged in on the motor side. regardless of power. 200-1000+
Originally Posted by Area47
(Post 4913175)
yes and no. depends on what the vehicle is being used for. key word that post was "if"
keep your knock sensors just desentisize them a lil so they wont give off false knock, keep your 02s for safety reasons
If your worried about getting alot of false knock you can desensitize them to a degree to try and help determine what is real and what isnt
La blue beat me to it haha!
Lol..took you a while
Ok. I will install them.
Why is it that people don't run the knock sensors sometimes? |
