Knock and O2 sensors?
I see plenty of guys not running knock sensors and/or 02s and I was wondering if I should run them? I have a large cam, running 110 fuel, and have a wideband.
I am guessing with large cams you get false knock? That is just an assumption and trying to determine if I need them or not.
P.S. Do I need to install the knock sensor if I am not hooking them up? Meaning will the hole they mount in leak if I don't install them?
11 Second Club
I would keep the knock sensors. They do a critical job in protecting your motor. You also definitely need the front O2 sensors. The rear O2 sensors are a different story, they can be eliminated, no problem.
