Just Got Hptuners...one Problem
Old Sep 23, 2006 | 06:57 AM
COLDZ71's Avatar
Default Just Got Hptuners...one Problem
When I go to the VCM Editor, click Flash, then entire, it says, " no vehicle found check to make sure key is in run position." I have tried it a couple different ways and I couldnt get past this point. Anyone have experience with this problem? I would like to get it fixed soon so I can start tuning away this weekend . Please help!!!
Old Sep 23, 2006 | 07:13 AM
TIM Z's Avatar
11 sec. Truck Mod
Dumb ? but what year vehicle are you tuning?, It would scan my dad's 99 suburban but wouldnt tune it cuz it wasnt supported.
Old Sep 23, 2006 | 10:43 PM
COLDZ71's Avatar
I trying to tune my truck, the one in my sig. Are the only fuses that would effect the tuning software from recognizing the vehicle, the ones that are located on the right side of the dashboard? Or do the ones under the hood matter?
Old Sep 23, 2006 | 11:05 PM
Bowtie70SS's Avatar
Have you already read your VCM? Or will it read the VCM? Also the same fuse that supplies power to the connector is typically the same one as the cigarette lighter. You can click on the help tab and it will show what vehicles are supported.
Dave
Old Sep 23, 2006 | 11:15 PM
Wheatley's Avatar
Truck Sponsor
check the cig light fuse and then let us know!
Old Sep 23, 2006 | 11:44 PM
foff667's Avatar
LS1TECH Sponsor
also READ THE HELP FILE!!! WHY ARE YOU DOING A WRITE ENTIRE? 99.9% of the time it is unnecessary to do a write entire & your only asking for trouble by doing so.
Old Sep 24, 2006 | 12:03 AM
nonnieselman's Avatar
yea check and make sure your Cig lighters work. if not you got a fuse blown. that fuse also sends power to the OBDII thing. you wont be able to do anything if its blown.
Old Sep 24, 2006 | 12:05 AM
Wheatley's Avatar
Truck Sponsor
One of the MAIN reasons to do an entire write is if you want to lock the PCM
Old Sep 24, 2006 | 07:29 AM
COLDZ71's Avatar
Not to sound like a complete dumbass, but, is the cig fuse marked as something else? Its in the fuse panel on the left of the dash correct?
Old Sep 24, 2006 | 07:34 AM
COLDZ71's Avatar
I understand what you are saying. I have read all the help files and FAQs. I should have explained myself a little better. I was following the setup directions and it said go to VCM Editor, click Flash, then Read Entire. It said if the vehicle was not supported then it will prompt you to choose if you want to at that time. I have been trying to follow the setup to a T.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
