Just finished my lq9 swap but having problems...help!!
Old Nov 12, 2011 | 01:10 PM
CalEditor@PCMCalibrators's Avatar
FormerVendor
Lots of bad info here.
What is the 8th digit of the VIN on the 02 Yukon?
You stated it is a LQ9 from a Escalade correct?
LQ9's come with 4L60E's or 65's
I don't want to get into everything else on how and why, but if you unplug the MAF and start the truck does the SES flash?
Old Nov 12, 2011 | 10:35 PM
jerrynaranjo08's Avatar
Hey Cal
the 8th digit of the yukon is a " T "
and the engine is off an escalade with a 65E trans and i also have a 65E trans
i havent unplugged the MAF to see if the ses flashes...ses is check engine light right?
i will check this in the morning and get back to you?
Old Nov 12, 2011 | 10:41 PM
mcfarlnd's Avatar
Un-Registered User
Interested in the info if you dont mind posting it up. He is using his PCM from his original motor which was for a 5.3. The LQ9 PCM is not in the truck.
Old Nov 12, 2011 | 10:50 PM
Formerly 99-2door-08/30/2010
What year is the LQ9 PCM you have from?
Old Nov 13, 2011 | 12:25 AM
nonnieselman's Avatar
just a simple mail order tune would get you a step in the right direction with a stock LQ9 tune..
that might take care of all your problems..
Old Nov 13, 2011 | 04:12 PM
The lq9 pcm I have is out of an escalade 02 with a 65E trans and I also have a 65E trans...should I put the lq9 pcm in it and pull my 5.3 pcm so I can send it out for a tune?
Old Nov 13, 2011 | 05:14 PM
nickleahy23's Avatar
i wouldnt have even wasted my time with the stock pcm...you went through all of the work in swapping the motor, and you have a pcm with a 6.0 tune and a 4l65e trans, which is what you have, so why would u not put that in right away? hell I had a custom tune waiting a month before I even started my swap so I could have it fully driveable when the last bolt was tight.
Old Nov 13, 2011 | 05:55 PM
FormerVendor
No -- well if your Yukon is a 2wd or AWD you could, but not 4wd or Auto 4wd
Old Nov 13, 2011 | 06:18 PM
Exactly my thought cal...my truck is awd with an nvg149 case which is really independent from pcm...so I think I will be ok until I get it tuned?
Where can I get a good tune at a reasonable price?
Old Nov 13, 2011 | 07:33 PM
your transfer case has its own control module (tccm, under the dash on the drivers side) and should be completely unaffected by the pcm?
