Just finished my lq9 swap but having problems...help!!
Lots of bad info here.
What is the 8th digit of the VIN on the 02 Yukon?
You stated it is a LQ9 from a Escalade correct?
LQ9's come with 4L60E's or 65's
I don't want to get into everything else on how and why, but if you unplug the MAF and start the truck does the SES flash?
Hey Cal
the 8th digit of the yukon is a " T "
and the engine is off an escalade with a 65E trans and i also have a 65E trans
i havent unplugged the MAF to see if the ses flashes...ses is check engine light right?
i will check this in the morning and get back to you?
i wouldnt have even wasted my time with the stock pcm...you went through all of the work in swapping the motor, and you have a pcm with a 6.0 tune and a 4l65e trans, which is what you have, so why would u not put that in right away? hell I had a custom tune waiting a month before I even started my swap so I could have it fully driveable when the last bolt was tight.
