Joshua's Special Place
Old Jul 8, 2008 | 06:19 PM
viciousknid's Avatar
Where's the Beef?
Default Joshua's Special Place
Okay. I can't make heads or tails out of anything so I'm lookin to you guys to get me started. I think my timing is a little high in spots. It sounds rich/lean at around 4krpm.
I'm posting up my log i did a couple weeks ago. This was just a tune we threw in to get it running better than it was.
I'm still trying to get a calculated PID figured out before I can mess with the VE table any.
When I let off the gas at cruise the RPM's don't drop unless i slow it down with the brakes but then never goes below 1000rpm.
Have a gander and let me know what I should do.
File Type: efi
File Type: tun
Old Jul 8, 2008 | 06:20 PM
Where's the Beef?
I'm not looking to have people do the tuning for me, just want to be pointed in the right direction.
Old Jul 8, 2008 | 06:30 PM
dirt track racer 81's Avatar
i will look at it when i get back..you need a wideband
Old Jul 8, 2008 | 06:31 PM
Stoichiometric's Avatar
I need to download v7.5 to look at your log, but I checked out your timing and made some adjustments. You can try these high and low octane tables and go from there. What cam do you have? Have you printed the autoVE instructions and tried to get that started?
File Type: tun
Old Jul 8, 2008 | 06:34 PM
BlackGMC's Avatar
Resident Retard
For starters in your log, you need to deselect one of the IDC% PIDs, your really only need to log one, that will get your channels down to 23, currently your logging 25 which slows down your frames per second in logging....
Old Jul 8, 2008 | 06:45 PM
how bout you get you a wideband and get it integrated into your lap top and bring it to me ill go over everything with you..
Old Jul 8, 2008 | 06:53 PM
Where's the Beef?
How bout you buy me a wideband and you got a deal.
I could go ahead and get one but then i have to wait on getting the gears in.
Old Jul 8, 2008 | 06:57 PM
gears can wait
Old Jul 8, 2008 | 06:59 PM
Where's the Beef?
gears can wait
If i'm just using it for tuning can I leave it hooked up without buying a gauge? cuz gauges are effin expensive.
Old Jul 8, 2008 | 07:02 PM
The heater needs to run when the sensor is in your exhaust and the truck is running, that is all.
