Intake Manifold Swap...
Old Mar 6, 2007 | 01:11 PM
spinz71's Avatar
Default Intake Manifold Swap...
If I swap out the stock manifold to a Vic Jr., is a re-tune required? Nothing else is changing. I'd like to think the current tune would be close enough to get from DFW to SA.
Old Mar 6, 2007 | 03:05 PM
12secSS's Avatar
Is this for the truck in your sig? If so, actually regardless, you will need a tune. The two intakes flow very differently, which may affect your fueling severly. I know the single planes flow a hell of a lot more air then an LS1/6 intake, let alone a truck intake. You will be running lean.
Old Mar 6, 2007 | 03:22 PM
spinz71's Avatar
Yeah...the truck in the sig. Dang, I was hoping that I could get by and ease it down to San Antonio to let Allen tune it.
Old Mar 6, 2007 | 03:29 PM
dc_justin's Avatar
Hello Dave
If you're closed loop and running a MAF, you should be able to get by on that drive. The system will compensate as much as it can for this change. I just wouldn't try and hot rod it til you have it re-tuned.
If you're closed loop speed density, then stay out of boost. If you're open loop speed density, then I wouldn't drive it.
Justin
Old Mar 6, 2007 | 04:16 PM
Bowtie70SS's Avatar
If you drive it definately watch the wide band and go easy. At cruise conditions you should be at 14.6-14.7.
Dave
Old Mar 6, 2007 | 04:33 PM
spinz71's Avatar
It is MAF and closed loop (I assume). I getting Allen to do an SD tune when I get there.
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
