Intake Manifold Swap...
If I swap out the stock manifold to a Vic Jr., is a re-tune required? Nothing else is changing. I'd like to think the current tune would be close enough to get from DFW to SA.
Is this for the truck in your sig? If so, actually regardless, you will need a tune. The two intakes flow very differently, which may affect your fueling severly. I know the single planes flow a hell of a lot more air then an LS1/6 intake, let alone a truck intake. You will be running lean.
Originally Posted by spinz71
Yeah...the truck in the sig.
Dang, I was hoping that I could get by and ease it down to San Antonio to let Allen tune it.
Dang, I was hoping that I could get by and ease it down to San Antonio to let Allen tune it.If you're closed loop speed density, then stay out of boost. If you're open loop speed density, then I wouldn't drive it.
Justin
