Installed TR6's now a missfire.
Old Aug 3, 2011 | 10:51 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Not much else it could be, really.
Old Aug 4, 2011 | 07:53 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
You realize this is only happening because I helped you put the blower on right?
Old Aug 4, 2011 | 08:58 AM
chevrolet all the way's Avatar
i ran some BR7EFs in my setup and my truck FREAKED out. i switched back to TR6s and no more problem. maybe your setup just doesnt like the 6s??
Old Aug 4, 2011 | 10:02 AM
jg53's Avatar
Cody, I know! I royally messed up letting you touch my truck! lol
Old Aug 4, 2011 | 12:24 PM
budhayes3's Avatar
PT's Slowest Truck
If the wires are on all of the way, and none of the wires got damaged during removal (might look good on the outside but be broken internally) you might have a cracked plug. Sometimes the crack is so small, like a hairline, that it's hard to see until you have a carbon trail...
Old Aug 4, 2011 | 06:56 PM
BlackGMC's Avatar
Resident Retard
I just put a set of tr6s in my truck to see if it would help with the higer compression (10.8ish). I have no issues at idle or wot. If anything it runs slightly better and i am NA.
Old Aug 4, 2011 | 10:54 PM
jg53's Avatar
Well didnt have a chance to work on it today, tomorrow it will be.
However my gas mileage has decreased by half. it just eats gas...any ideas?
Old Aug 5, 2011 | 08:12 PM
jg53's Avatar
Well I swapped out the TR6's for the stock plugs this morning.
Everything is back to normal. no missfires.
It might have been the wires not making good contact, or the gap.
I will reinstall these when me and cody tackle the Cam/head work in a month or so. I will see how they go then
Old Aug 5, 2011 | 08:19 PM
1slow01Z71's Avatar
Before we tear down the motor we will swap plugs again and see if the misfire returns. If it does we will swap the wires with some of mine and see if it goes away. I think you just arent getting enough heat in the cylinder to warrant the colder plug just yet with only 5-6#s of boost and 11*s of timing.
And asnwer your damn text message
Old Aug 5, 2011 | 08:22 PM
jg53's Avatar
Sounds like a plan cody.
and thanks for reminding me!
LCHEE
Oct 24, 2020 04:10 PM
GXPJAY
Nov 5, 2015 06:49 AM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
