installed some long tubes..
Old Mar 19, 2006 | 05:40 PM
ThunderZ28's Avatar
12 Second Club
Default installed some long tubes..
what needs to be adjusted..
my ltrms are at +25,
and my O2's are at 350 at idle..
what gives???
is it that big of a diffrence going to LT's????
Old Mar 19, 2006 | 05:49 PM
chrisj6's Avatar
no i think that has to do with the position of your sensors, how far downstream from the collectors are your sensors placed? You might have to tweak your trims a bit, but the only thing you should really have to end up doing is adding a bit of fuel on the midrange and a bit more on the topend.
Chris
Old Mar 19, 2006 | 05:52 PM
ThunderZ28's Avatar
12 Second Club
they are about 4 inches from the collectors give or take..
Old Mar 19, 2006 | 08:02 PM
ThunderZ28's Avatar
12 Second Club
Old Mar 19, 2006 | 08:52 PM
rgvsierra's Avatar
plus 25 at idle usually shows a sign of a leak.. unless you adjusted something in your tune wrong.
oh, wait, is this 25 at idle or driving?
Old Mar 19, 2006 | 09:08 PM
1slowsilverado's Avatar
I had the same problem, Not with the trims but with the 02 sensors not switching. Are your headers uncoated? I had to go with a different 02 sensor and swap the pig tails to be a direct fit.
Old Mar 19, 2006 | 09:29 PM
ThunderZ28's Avatar
12 Second Club
+25 at idle
and the O2's are at 350 at idle
and they are armour coated..
the O2's screwed right and I tightned them down..
headers came with a block off plate for the EGR, that I put on there..
but the freaking thing is so loud I doubt I could even hear a leak if there was one..
sounds like I am in the garage at a nascar race..
Old Mar 19, 2006 | 09:44 PM
Put alittle tranny fluid in the main vacumm line. It will smoke like crazy at the leak and **** your neighbors off. Any codes yet, or havent put many miles on it since install?
Old Mar 19, 2006 | 09:59 PM
ThunderZ28's Avatar
12 Second Club
well I havnt even been able to drive..
it's just the headers.. tomorrow I am going to get the rest of the exhaust put on...
Old Mar 19, 2006 | 10:13 PM
Well after you get it all put back together and drivable. Youll probaly be fine, If your running open headers? It not going to read right. Thats a major leak right at the 02 sensor...
