which ignition system for forced induction
Old Feb 23, 2012 | 10:40 PM
  #21
AKlowriderZ71's Avatar
11 Second Hall Moniter
Yes that's right.
Old Feb 23, 2012 | 10:49 PM
  #22
I might have missed it, but what kind of fuel are you gonna burn?
Old Feb 23, 2012 | 10:50 PM
  #23
Atomic's Avatar
I have a gauge for that
Correct. NGK plugs get colder as the number increases. Everyone else is the opposite.
Plug heat range is a comprimise of high-power stability and low-power driveability. Meaning plugs that are meant for putting around in a 200hp engine are going to be far too hot for 20lbs of boost on anything. And the plugs suitable for 20 pounds are not going to be as smooth at low load, being most noticeable at idle. Colder plugs are also more susceptible to fouling at low loads due to it not getting hot enough to burn off the carbon deposits. Just something to think about.
Old Feb 23, 2012 | 10:54 PM
  #24
You want the hottest plugs possible, that will run properly withou turning into a "glow plug" and causing pre-ignition. You have to read the plugs to see what's going on in there.
  #25
smokeshow's Avatar
Mod with training wheels
Its not so bad with the new cam cause it doesn't pull as much vacuum, but the last cam I ran would cruise around 40mph at like 16inhg, and the TR7s made it chug real hard cause of the random misfire. Converter absorbs it unlocked, but locked up it got nasty. Plug gap can mitigate to some extent, but colder high power plugs will never quite drive the same as stock stuff.
Old Feb 23, 2012 | 10:58 PM
  #26
nonnieselman's Avatar
Never thought bout that. Im still runnin the same 30 gap TR6 plugs i was running couple years ago when i had the turbo on.
Prolly gonna put the tr6 in the samurai and these new tr5's in the silverado. Hum.
Old Feb 23, 2012 | 11:09 PM
  #27
Atomic's Avatar
Roger pretty much nailed it. I think Chase was using the heat range 8 plugs on his SSS and was fouling plugs every few thousand miles because they were too cold.
Also the whole "heat range" nomenclature is a bit misleading. What is really going on is the hotter plugs have more contact area with the combustion gases, therby having a higher heat transfer rate, whereas colder plugs have less material standing out in the chamber so they dont heat up as quickly. Heres a picture to illistrate the point. Notice the great area exposed to gas of the "hot" plug.
Old Feb 23, 2012 | 11:15 PM
  #28
GregoryTowing's Avatar
Registered User
What fuel and induction will be used? I am running a super mag 3 on my turbo motor, a sprint mag should work for longer distance driving, I have not tried it yet but it is on the table. I am running .016" gap, mechanical alky injection, and 50+ lbs of boost with 29-33* timing. the misfires will not hurt, the backfires get ugly.
Old Feb 24, 2012 | 06:46 AM
  #29
oldred95's Avatar
91 octane for everyday driving and race gas if I feel like I need to see what it can really do. There is no E85 in this area.
The general consensus is that coil near plug will do just fine and there is no real benefit to a distributor and external coil for boosted applications?
FlowmasterMufflers
Nov 24, 2015 01:00 PM
racedad70
Sep 16, 2015 01:51 PM
lxcoupe
Sep 11, 2015 03:17 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
