IAT Bias Issue?
Old Jul 14, 2008 | 09:25 PM
KySilverado's Avatar
Default IAT Bias Issue?
Frustrating. The last time I tuned my VE it went much easier. Here are screen shots of 2 logs. Nothing in the tune changed. First is a log of a run to town to gas up the truck. Get to the gas station. Stop the log. Fill up. Take off and log the same route back. As you can see on the trip back averaged about 6% leaner than the trip up.
WTF? Bias issue? The gas?
Trip to station.
Return trip.
Old Jul 14, 2008 | 09:28 PM
dc_justin's Avatar
Hello Dave
On a warm-restart, heat soak is a big issue for the stock IAT sensor in the radix.
I purchased a new thermistor for my IAT from Omega, just haven't had a chance to install it yet. Supposedley, it recovers significantly faster.
Old Jul 14, 2008 | 09:34 PM
I remember reading about that IAT sensor once upon a time. So basically it is a heat soak issue and the bias? Looking at the logs the IAT was higher on the return trip.
Old Jul 14, 2008 | 09:43 PM
dc_justin's Avatar
Hello Dave
It's not really the bias, just heat soak. Air coming into the engine is cooler than either the heat soaked IAT sensor or a biased measurement using IAT+ECT can measure, causing it to run lean.
Old Jul 14, 2008 | 09:49 PM
Thanks for the input. Much appreciated. Care to share the IAT sensor part number. I've found a couple FJO and MSD but are threaded. Don't know if they are direct replacement for the Maggie.
Old Jul 14, 2008 | 11:06 PM
Found a good write up on the omega sensor.
http://kb.ls1gto.com/KB/article.aspx?id=10279
I'll try it but I am skeptical. Two things come to mind. 1> The sensor is encased in plastic. Plastic is a very good insulator. 2> This unit responds quicker but the time that I drove should have allowed for the sensor or charger cool down. It didn't.
Old Jul 14, 2008 | 11:37 PM
charcold-bowtie's Avatar
I know the stock MAF sensore is slow acting, compared to a relocated one, there is no difference. The MAF one is very slow.
Old Jul 15, 2008 | 12:02 AM
I just ordered the Omega sensor. I'll pick up the Camaro IAT sensor at a parts house and do the mod. I'm going to play with the bias table in the meantime and see where that gets me.
Old Jul 15, 2008 | 03:33 AM
laynlow77's Avatar
and you havent told me this....why!
Old Jul 15, 2008 | 09:10 AM
Wilde Racing's Avatar
How do I change this text
what is you bias table set at now?
